» alignment specs
Today at 12:53 am by sharkey
Yesterday at 9:46 am by JSP
» Transaxle rebuild
» Tpc LS adapter plate
Clutch and Flywheel. What should I run?
Post  the951racer on Wed Aug 22, 2012 9:43 am
Hey guys....I'm still plugging alon with my build as I just did the 5th gear swap a couple weeks ago. Anyway, what is the best clutch and flywheel setup to run for street drivability. I'm not planning on racing the car but, I will drive it hard on occasion. More like just street cruising with the wife and going to car shows. The motor should put down close to 500 hp per my tuner and machine shop guy. Just wondering what the best setup would be. Pros/Cons with aluminum flywheel ect.
Thanks in advance.
the951racer
Re: Clutch and Flywheel. What should I run?
Post  Rich L. on Wed Aug 22, 2012 10:56 am
I'm running the setup TPC sells, SPEC aluminum flywheel, PP and stage 2 disc. No cons to report.
Post  the951racer on Wed Aug 22, 2012 12:24 pm
Rich L. wrote:I'm running the setup TPC sells, SPEC aluminum flywheel, PP and stage 2 disc. No cons to report.
By setup TPc sells...What setup are you referring to? Maybe I'm missing something. Do they sell a kit that contains everything you listed? Or is that suggested by Eric?
the951racer
Post  Rich L. on Wed Aug 22, 2012 12:32 pm
Yeah, TPC is a SPEC dealer. I bought the whole setup from them.
Post  the951racer on Wed Aug 22, 2012 12:48 pm
Oh ok. Was thinking that but, didn't remember for sure. No chatter or vibration for everyday use?
the951racer
Post  Rich L. on Wed Aug 22, 2012 12:50 pm
Nope, works great. Holds my 430hp motor just fine. Kit comes with shim and alignment tool. Shim measurement is a bit of a PITA but well documented.
Post  the951racer on Thu Aug 23, 2012 8:05 am
Cool. Sounds good man. Thanks for the info.
the951racer
