AC Question
AC Question
Before I put my 948 into storage I was chasing a AC leak. I could not find a leak in the engine bay, compressor or radiator areas.
Has anyone any experience of ac leaks under the dash and where to look for them?
Re: AC Question
Hey Mike, get a can of the A/C refrigerant with dye in it and the glasses, etc. It's cheap, available at Advanced, Pep Boys, etc, and you will save a ton of time looking for the leak. I've used this before, worked like a charm.
Re: AC Question
As the other mike said a UV dye is a must......
The best way to see, and change out, the expansion valve (and connections) is by removing the HVAC blower cover in the rain tray. I don't remember if you can see much of the evap core though.
If you haven't already changed the expansion valve, this would be a good time to do it.....I picked that and a dryer up from Polar Bear Inc.....you will also want some cork filled insulation tape, to wrap up the valve and lines afterwards.
» FOR SALE - 1987 Turbos with Corvette LS1 - Black
» Oil Pan question
» 944 turbo radiator switch bung size?
» Oil Pan question
