Uh oh, loss of power, weird noise and motor shaking
+3
7 posters
On my way home from the track yesterday the car started to shake. There was a loud harmonic resonance and I pretty much lost all power on the motor.
Since I was close to home I kept going. When I got off the freeway and ran it through the gears from a stop, the motor seemed fine. Normal power, no weird noises and no vibration.
WTF? I did notice I didn't have the power I normally had on track this past weekend, but I chalked it up to having the cats back in the car. I also saw that the car was running a bit rich, with AFR's around 12 vs the normal 12.6-12.8 I usually see....
Besides a compression test, what should I be looking for and doing?
Re: Uh oh, loss of power, weird noise and motor shaking
Bummer Doc. It sounds great and seemed strong in the vid you posted. How were the water temps? First thing I'd do is pull the plugs and have a look at them. I had a popping and power loss at WOT that turned out to be a plug wire that had rubbed on the header and split. Good luck with it.
I usually pull on that yellow GT3 and it was walking away from me. It's just weird, I'm about 3-5 seconds off the pace from last year. When I dynoed the car this year it was 20rwhp down from last year too...
Water temps were better with the bigger radiator, around 230-240, but I still need them lower. Looks like I'll be opening up the front bumper where the license plate mounts and see how much that helps.
I'll check the plugs and see what they look like. How do you do a compression test on a coil pack car? With a dizzy you'd just pull the coil wire, but you can't do that with coil packs...
Unplugging the white connector at each row of coils does the same thing.
Ok, easy enough. I'll have to pull the plugs for a compression test anyways...
Yes, I burned through a plug wire on one of the first test days and it killed the power. I'm still learning the LS motor and trouble shooting, so can't be of much help here.
Wait on cutting the front bumper up, I'll be testing mine this weekend at Barber and will let you know if it helps.
I would moitor misfires while running the car under load, just because it doesnt set a code doesnt mean its not misfiring. Does HPT give you a power balance test? it might be called cylinder balance test. I would suspect fuel, when was the last time you filled up? Normal gas station? Is it a national chain? I typically only get fuel from BP/Shell i see too many people come in with shitty gas.
Marky522- Posts : 175
Sounds like an O2 sensor might have gone south. Check plugs and see if one side of the engine looks fat or if you have a scanner check 02 readings and see if one is lazy or dead.
968LS3RS- Posts : 10
I recently replaced both pre cat O2 sensors, so I doubt that's it. I know u had a cylinder imbalance due to an exhaust leak on the drivers side, but only at idle. I fixed that tonight.
Just because they are new does not mean one could not fail prematurely.
I just had the same issue. It turned out to be bad vacuum leak.
zeusrotty- Posts : 444
Hmm, wonder if replacing that smog valve will clear this up then...
docwyte wrote:Hmm, wonder if replacing that smog valve will clear this up then...
My issue was the throttle body has a block off on the side of it that wore through, and I am pretty sure is what caused a backfire and stall that blew the block-off for the brake booster on the back of the intake manifold. Are you getting any codes?
Nope,no codes, but I do have a bank imbalance at idle. One of the nubs had broken off my smog pump valve that led to the fitting on the drivers side header...
docwyte wrote:Nope,no codes, but I do have a bank imbalance at idle. One of the nubs had broken off my smog pump valve that led to the fitting on the drivers side header...
Ah, we don't have to have smog in Illinois for cars this old.
Please don't tell me you are running the same tune as before. There is CAT protection built into the ECU that can be turned on and off that would save the CATs from wearing quickly. The car should be retuned as well, and the AFRs should be dialed in closer now compared to running without CATs. All the O2 sensors should be turned back on as well.
robstah- Posts : 352
Today at 12:47 am by sharkey
