» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
1st and 2nd gear hard to get into when hot.
Page 2 of 2 Previous  1, 2
Re: 1st and 2nd gear hard to get into when hot.
Post  aixgelo78 on Wed Jul 25, 2012 8:29 pm
I must have adjusted the clutch rod 5-6 times already, about 3/4" worth. I adjusted it another 1/8" of an inch today and it made a world of a difference. Not perfect yet, but its a big step to the right direction.
Going thru my punch list.
aixgelo78
Post  Arthropraxis on Sun Jul 29, 2012 2:25 pm
aixgelo78 wrote:I must have adjusted the clutch rod 5-6 times already, about 3/4" worth. I adjusted it another 1/8" of an inch today and it made a world of a difference. Not perfect yet, but its a big step to the right direction.
How do you have it adjusted? Mine is out far enough to close the factory clutch pedal switch. Do you have yours adjusted out further than that?
What kind of fluid are you running for the slave? I still get the same problem as you, it was much worse with the old slave. I was thinking about switching to some high temp brake fluid since I have the SS clutch line running right behind the block. It may suffer from heat soak. Any opinions?
Post  aixgelo78 on Mon Jul 30, 2012 10:08 pm
I don't recall the clutch switch, but Ill take a look at it as soon as I get a chance and report back.
As for the fluid, I am using some valvoline synthetic, nothing special. Im sure some better fluid will help, but how much though? I do plan on upgrading the fluid myself...I just have to see what I good stuff I have laying around...
aixgelo78
Post  Arthropraxis on Mon Aug 06, 2012 7:28 pm
I could always feel and hear a metallic shock when shifting from the shifter through the intermediate tube. It went away after removing the exhaust hanger. Apparently, the intermediate tube moves in an arc and contacts the hangar that goes over the torque tube. That could cause some of the binding during shifting.
Post  Arthropraxis on Wed Aug 08, 2012 9:22 pm
I don't know if you have the remote bleeder that Sloan was selling. If you have one, try bleeding the slave again with the tip of the bleeder immersed in brake fluid. The speedbleeder on the end of it sucks air when the pedal comes back up. I did this last night and it helped mine. You may have already tried this, just putting it out there.
Post  aixgelo78 on Fri Aug 10, 2012 11:20 pm
Arthropraxis wrote:I don't know if you have the remote bleeder that Sloan was selling. If you have one, try bleeding the slave again with the tip of the bleeder immersed in brake fluid. The speedbleeder on the end of it sucks air when the pedal comes back up. I did this last night and it helped mine. You may have already tried this, just putting it out there.
I did this somewhat. I used a clear tube and I placed the waste reservoir higher. Pretty much the same concept.
The car has been sitting, Ive been busy. Hopefully Ill get a chance to work on it this weekend.
aixgelo78
Post  Howell944 on Fri Oct 25, 2013 11:38 am
It's funny mine gets worse in the cold weather. I chalk it up to the cold condencing the flued just a hair.
Howell944
Shifting problem solved.
Post  simon123 on Sat Jan 04, 2014 4:47 pm
I recently changed my 5th gear to a Tall set. I did it in the car by removing a section of the spare wheel well.
I had previously changed the 5th gear during the LS1 conversion  and mistakenly changed like for like. While doing this I had the rear cover machined and installed a steel stiffener plate.
This time I carefully inspected the steel plate and realised the gear shift rods passed through it and the holes were a very close fit. Examining the end cover I concluded that these holes did not provide any bearing surface, I eased them out a few thousands before re-assembly.
I now have a tall 5th and a shifter that's is much easier to use in 1st and 2nd. gears.
simon123
