School me on manual rack + 3/4" xmbr drop
I've looked but haven't found the answer yet, though I'm sure it's on here somewhere. I'm switching to a manual steering rack, and I know I have a bunch of parts I need to get beyond the rack itself (got that already). When I bought one of xschop's kits, I know he included a "bump-steer tie-rod drop block" that I'm assuming corrects the steering geometry now that the rack is 3/4" lower, but the control arm is in the same spot as before.
Anyway, what I'm unclear on is where all these parts fit together, and which additional parts I need. I assume the order on a side is: rack > inner tie rod > tie-rod drop block > outer tie rod end > spindle. But I'm sorta swimming in parts numbers right now and have suitably lost myself. Does anyone have a pic of how one side of the rack goes together in the aforementioned config? Just that would probably get me most of the way.
Gracias...
Gracias...
Big E- Posts : 35
Re: School me on manual rack + 3/4" xmbr drop
Here's an old post from fliermike45 on the subject:
HTH,
HTH,
