09 June PCA Autocross Event
Looks like the stiffer springs helped some. Maybe I'll go up to 350-375#.
skywalker01- Posts : 477
video
Another good vid keep posting. thanks.
kevin924kevin- Posts : 927
Re: 09 June PCA Autocross Event
Yeah - learn from my mistakes! Definitely want to go with stiffer springs for autocross!! Thanks for the comment
It looks like it has less pitch & roll than the last course. It also appeared to rotate less eagerly, which in your case is a good thing....skywalker01 wrote:Looks like the stiffer springs helped some. Maybe I'll go up to 350-375#.
Did it feel different/better/worse?
948 wrote:It looks like it has less pitch & roll than the last course. It also appeared to rotate less eagerly, which in your case is a good thing....
Felt much better this time out with the lower tire pressures. Seemed a little more surefooted going through the boxes at higher speed. The real test of this setup though will be the SCCA event on the 23rd and 24th
