» JP's LS1 Conversion
Yesterday at 8:32 pm by jpkinerk
Yesterday at 8:13 pm by gdopnt
Yesterday at 9:56 am by superman22x
» LS3 Exhaust
Sat Jan 20, 2018 11:12 pm by sharkey
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
» alignment specs
Fri Jan 19, 2018 4:22 pm by Hotrodz of Dallas
» 1984 Gen IV 5.3 Swap
Fri Jan 19, 2018 2:03 pm by superman22x
January 2018
mounting the bell housing to the torque tube question
Post  944_345.7 on Thu Jun 21, 2012 5:34 pm
I have a weird question.....
When you are mounting the bell housing to the torque tube are there typically washers that go between the mating surface or does aluminum adapter mount flush to the steel? The reason I ask is that my RH bell housing and adapter had 1mm washers that were stuck to the bolt holes via thread locker, (like it was supposed to be there) and I was curious how other were mounting their bell housings.
944_345.7
Re: mounting the bell housing to the torque tube question
Post  Admin on Thu Jun 21, 2012 7:42 pm
Adapter plate to steel is how we always do it.
Post  acorad on Fri Jun 22, 2012 11:17 am
944_345.7 wrote:I have a weird question.....
I recently took my RH adapter off and it also had those washers as you describe between it and the TT. I left them out when I reassembled, as they seemed way too ghetto for my tastes. Do you suppose the washers were to correct a slightly too-thin adapter plate?
Post  944_345.7 on Fri Jun 22, 2012 11:45 am
[/quote]I recently took my RH adapter off and it also had those washers as you describe between it and the TT. I left them out when I reassembled, as they seemed way too ghetto for my tastes. Do you suppose the washers were to correct a slightly too-thin adapter plate?[/quote]
No idea. I was wondering if it was a corrosion correction decreasing the contact patch with the dissimilar metals. I went ahead and took them out too. I was questioning how the drive shaft seated into the bearing and figured that pushing the shaft back further via the washers was not ideal. I am going to install my engine on Sunday hopefully and am going to take a careful look at it.
944_345.7
Post  xschop on Fri Jun 22, 2012 11:47 am
Grenade Hybrids designed it that way so every time it rains you'll get free TT bearing lubricant Razz
