» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
Controlling the water temps on the track
Page 6 of 6 Previous  1, 2, 3, 4, 5, 6
Re: Controlling the water temps on the track
Post  phlip on Mon Oct 06, 2014 2:18 pm
zeusrotty wrote:i am running this radiator.
http://www.summitracing.com/parts/gri-1-85201-h
Mounting was done with aluminum brackets. Super easy and you could DIY.  The car is in now getting new heads and a new cam and tune so i cant really take pics. I am also running dual 10" spal fans at 2200 cfm a piece.  i did have to have a bug hole put in the lower left of the rad for the stock Porsche temp sensor.  It works really well.
Thanks for the info. I my ebay radiator fails to cool enough I'll be looking for options.
phlip
Post  mr965 on Mon Oct 06, 2014 11:54 pm
Zeusrotty, what are your water and oil temps on track?
mr965
Post  zeusrotty on Tue Oct 07, 2014 4:19 pm
I havent had it out yet but in stop and go traffic in 90 degree weather I don't get over 200 ever.
zeusrotty
Post  zeusrotty on Fri May 20, 2016 7:54 pm
Hey guys, how are you bleeding your coolant systems. I have my radiator plumbed to the reservoir, my steam vents 4 way plumbed to my steam vent port on my reservoir, and I can't seem to get it bled correctly. I jacked up the drivers side of the car to see if that would help and it didn't. Any good ideas?
zeusrotty
Post  Rich L. on Sat May 21, 2016 10:28 am
I run mine 'til the fan kicks on with the reservoir cap off so it doesn't pressurize. Then I pull off the line at the steam vent port, this hisses, burbles then run straight water which is when I put the line back on. Make sure to keep the reservoir topped up during all of this. Good luck.
Post  zeusrotty on Sat May 21, 2016 12:11 pm
Thanks Rich, I'll give that a shot.
zeusrotty
