Today at 6:48 am by Michael B.
» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Using GM "F body" PS pump and Hydroboost, is original reservoir OK?
Post  grobb284 on Sun Jun 10, 2012 3:13 pm
For those with the LS1 conversion, using the GM "F body" PS pump. and also hydroboost, did you continue to use the GM plastic integral reservoir, or go to a remote PS reservoir?
Anyone using the Trans Am PS cooler?
Pictures are always nice.
grobb284
PS Pump
Post  fliermike45 on Sun Jun 10, 2012 5:41 pm
I used a Turn One PS Pump which is an uprated GM pump and appears to use the stock reservoir. According to the experts the stock GM pump cannot generate sufficient pressure for the Porsche steering rack. I have not changed the reservoir with the addition of Hydroboost. I moved the stock PS cooler from the pax side to the driver's side.
Picture taken before adding the Hydroboost.
Re: Using GM "F body" PS pump and Hydroboost, is original reservoir OK?
Post  Admin on Sun Jun 10, 2012 8:37 pm
I've used factory GM pumps with the plastic res, and a cooler and have had no real complaints.
Post  docwyte on Mon Jun 11, 2012 9:09 am
TonyG would boil the power steering fluid when he used the factory F body pump, even with a cooler on the track.
If the car is just a street car I'm sure it'll be fine, otherwise get the Turn1 pump. I have a Turn1 on my car with a cooler and I've never had an issue on the street or the track.
