» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
09 June PCA Autocross Event
Post  skywalker01 on Sat Jun 09, 2012 9:42 pm
Looks like the stiffer springs helped some. Maybe I'll go up to 350-375#.
skywalker01
skywalker01
video
Post  kevin924kevin on Sun Jun 10, 2012 12:45 pm
Another good vid keep posting. thanks.
Re: 09 June PCA Autocross Event
Post  skywalker01 on Sun Jun 10, 2012 9:54 pm
Yeah - learn from my mistakes! Definitely want to go with stiffer springs for autocross!! Very Happy Thanks for the comment
skywalker01
skywalker01
Post  948 on Mon Jun 11, 2012 6:53 am
skywalker01 wrote:Looks like the stiffer springs helped some. Maybe I'll go up to 350-375#.
It looks like it has less pitch & roll than the last course. It also appeared to rotate less eagerly, which in your case is a good thing....
Did it feel different/better/worse?
Post  skywalker01 on Mon Jun 11, 2012 11:46 am
948 wrote:It looks like it has less pitch & roll than the last course. It also appeared to rotate less eagerly, which in your case is a good thing....
Felt much better this time out with the lower tire pressures. Seemed a little more surefooted going through the boxes at higher speed. The real test of this setup though will be the SCCA event on the 23rd and 24th
skywalker01
skywalker01
