» Transaxle rebuild
» Tpc LS adapter plate
Tie rod End
Tie rod End
Post  Admin on Sat Aug 15, 2009 7:27 pm
Does anyone know what the angle of the taper of the tie rod end that goes into the spindle?
geometry
Post  xschop on Sat Aug 15, 2009 9:37 pm
I know first hand that all spindles from NA to M030 have the dims....12mm top, 13.5mm bottom and 18mm length. The pivot center of the tie rod joint is exactly 25mm from the bottom face of all the spindles when they are torqued down.
For reference.....
