928 TT dimensions
928 TT dimensions
I'm not sure what to think about the 928 TT's
I recently went to the Porsche graveyard and measured what I thought to be a 928 Manual TT. However there were shorter TT's and some that had extention tips that connected via a shaft adapter similat to the 944 TT to transaxle sleeves...
anyways here's what I found on a couple of the TT's (I think these were 5 speed TT's) I may stand corrected....
Re: 928 TT dimensions
Flange?
Bolt pattern?
The 928 uses a coupler @ the flywheel - can be eliminated when installing GM V8.
I came up with a 944 to 928 TT dimensional difference of 3.76".
Hmmm, sounds about right...(using the SMS method)
Bolt pattern?
gt1scca- Posts : 795
I am certified, Looks good to megt1scca wrote:using the SMS method
Tetzuoe- Posts : 178
Flange?
Bolt pattern?
After seeing all the 944 Flange dims off everywhere I didn't bother.....Figured I would use the SMS system when I make an adapter
It was dark inside the building and mosquitos galore, had to bail quickly
I did see that there was a short and long tube as well, maybe one was for Auto and the other for Manual, but not 100% sure either.
Hello,
This is my first time posting... I think there are at least two different lengths of torque tubes in the 928 manual cars. Perhaps the slip collar offers some minor tolerance for BH adapter length?
If we could just get the TT face dimensions... Not sure what SMS is. Must be something similar to my portable Lufkin dimensioning system ($6 at the HomeDepot)
Here is a picture I found in a TT rebuild post that adds some pieces to the puzzle
realcarfreak- Posts : 2
Here is another bit of information related to the original 928 manual configurations.. Single and Dual disk
Yep...
Saw those. Flange bolt pattern is what we still need.
S.M.S.:
S.M.S.:
Ok back on this subject. The first pic with the longer 1 piece shaft is the AUTOMATIC Torque Tube and the 5-speed has a coupler designed so clutch changes are easier....I wish the 944 had a 2-piece with coupler but that's another story.... Anyways that coupler has a maximun rotating dia. of 2.75" (Eric) and another measurement of 2.73" by Constantine. Measure twice cut once right? By the way, if you haven't heard, Constantine, the TT rebuild guru is building all-new 944 Torque Tube Shafts from stronger steel and even Zinc Plating them. So if you have a Renegade kit, you might want to contact him
Anyways, I don't build anything on SMS so I will get the 928 Flange dims from him and if Eric can confirm, we're on our way.
TT
Constantine rebuilt a 944 shaft for me, his work is first class.
» VSS Setup (and tuning)...
» Drive shaft too short to reach pilot bearning
» 85.5 CV joint bolt dimensions
