» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
disengagement issues
Post  cfgioja on Sat May 19, 2012 3:35 pm
I have been searching the post and found plenty of talk about the clucth master cylinder. Want i didnt see was a positive answer to the question. Not trying to bring back an old topic or anything though.
While driving i notice the i find my self moving faster than the clutch pedal and feel the gears trying to grab as im am switching out of gears. I figure this goes to the master cylinder topic. If i slow down and focus on pushing in the pedal completely i do not have an issue, this just seems to take alot of time for a gear shift.
So i guess i am asking if there is a master that will require about half of the stock pedal distance and still allow the clutch to fully disengage?
Re: disengagement issues
Post  Arthropraxis on Sat May 19, 2012 5:06 pm
What is your set up now? I did some reading on LS1tech.com and it was indicated the slave cylinder input line has a restriction and some drilling of the slave would help quicker engagement. The slight grinding may be due to the transaxle fluid. What type of transaxle do you have and when was the last time the fluid was changed? what fluid did you use? Did you measure to see if you needed a shim when installing the clutch? My car is having similar issues.
Post  944convert on Sat May 19, 2012 6:58 pm
After reading so many posts like this one, I've decided to go with a Wilwood 260-6088 master cylinder.
In testing it on my bench, I found it moves the TOB noticeably farther (over 1/8" more) and with a lot less effort (this is on both LUK LS1 and LUK LS7 self-adjusting OEM clutch kits).
The clutch begins to release about at about 33% downward pedal travel and fully releases at about 50% pedal travel.
The MC moves about 10% more fluid volume to extend the TOB piston travel and it does it with only a .700" diameter piston. The smaller diameter of course reduces the clutch pedal push effort...it went from ~43 pounds pedal effort with a .75" diameter cylinder to ~38 pounds pedal effort with the .700” with the LS7 PP, and only ~29 pounds pedal effort with a LUK LS1 setup! I can see how this setup would make the clutch release/engagement modulation smoother as well.
Post  944-LT1 on Sat May 19, 2012 7:57 pm
Sounds to me that the gear set isnt slowing down fast enough; meaning, the gears are spinning faster than the synchro mesh speed. This could be transaxle fluid all leaked out, too thin, old fluid or worn out synchros. This is common when some switch to a fluid like royal purple.
If this is a new "all-of-a-sudden" problem, the clutch disc may not be fully disengaging from the flywheel due to air getting into the system (try bleeding the clutch again).
But, could be as simple as low clutch fluid level!
Post  cfgioja on Sun May 20, 2012 8:51 pm
Not a new problem. I have castrol 80w90 gear fluid. Topped off at fill hole. No spacer needed.
It happens occasionally when i dont get the pedal completely down.
Ill look at the mc you suggested
Post  Arthropraxis on Sun May 20, 2012 9:03 pm
How is your firewall? If you look at it while someone presses the clutch in how far, if any, does the master cylinder bulge out?
Post  Germerican on Fri Mar 15, 2013 8:38 pm
cfgioja wrote:I have been searching the post and found plenty of talk about the clucth master cylinder. Want i didnt see was a positive answer to the question. Not trying to bring back an old topic or anything though.
Did you ever get this figured out....mine does the same thing
Germerican
Post  Arthropraxis on Fri Mar 15, 2013 11:08 pm
Don't overlook the clutch/FW/PP itself. Before swapping my clutch for a LS7 unit, I thought my poor shifting transaxle was worn out and needed rebuilding. It shifts great now. I swapped it out chasing a vibration and killed two birds with one stone.
