» ecotec swap
Yesterday at 4:53 pm by Hotrodz of Dallas
» New 944 widebody & aero
Fri Mar 16, 2018 7:20 pm by scryfst
» Wilwood MC on it's side
Fri Mar 16, 2018 7:09 pm by scryfst
» V8 Conversion Parts
Wed Mar 14, 2018 12:15 am by Chaxce
Tue Mar 13, 2018 11:46 pm by Red944ls1
Mon Mar 12, 2018 8:32 pm by Patb
» Fuel pump options
Mon Mar 12, 2018 12:05 am by V8it
Sun Mar 11, 2018 10:56 pm by V8it
» Poly engine mounts melted
Sat Mar 10, 2018 1:11 pm by acorad
» JP's LS1 Conversion
Sat Mar 10, 2018 11:48 am by docwyte
March 2018
Cold Start Manners
Cold Start Manners
Post  Rich L. on Thu May 17, 2012 4:23 pm
Howdy. My LS1 does not like to idle when cold. On first start of the day I have to sit there and baby sit the throttle for the first minute or 2 or it'll die. Once it gets warmed up it idles at a rock steady 850 and has very good throttle response. So it seems to me to just be a problem in that "open loop" period on cold startup.
This seems to be a common problem as I see many threads on the various forums complaining of similar bahavior. There are suggestion to do a "TPS reset" and a "IAC relearn" but procedures vary. Does anyone have the true steps to perform these? I also see suggestions to clean the IAC and clean the MAF wire. Both of these parts I got used so I should try cleaning them. Has such cleaning helped any of y'all?
But the real culprit is probably the tune. My engine has fairly big cam and I read that it takes a lot of tuning time/data to get nice cold idle manners. I suppose it's likely the shop that rebuild and dyno-tuned my engine didn't really put the effort in for this. It's not the end of the world as once I get a couple minutes of running the engine is all good. Perhaps I should just be happy with that.
Any other suggestions for things to try short of getting it re-tuned?
Re: Cold Start Manners
Post  948inVA on Thu May 17, 2012 6:03 pm
Have you checked the coolant temp sensor on the driver's side head? Usually when it fails the PCM thinks the engine is warm.
Post  Rich L. on Thu May 17, 2012 7:42 pm
Ah, good thought. But when I connect the scan tool the PCM's water temp starts at ambient and climbs with the dash gauge. So I think it's reading correctly.
