The First E Rod crate motor install! (in a 968 at least)
+16
Bluemach1
RobotMachines
Tehone
zeusrotty
Diyman25
20 posters
This is the latest project that we just finished on Tuesday. It a 1993 968 Porsche Cab. We installed an E-Rod carb certified GM crate motor. It is a 6.2lt 435hp LS3 , with DBW and all the goodies.
erod
Very nice install. more pics please.
kevin924kevin- Posts : 927
Re: The First E Rod crate motor install! (in a 968 at least)
Cool Been contemplating swapping a V8 into my 1995 968 daily driver.
Here's a few more for you!
Beautiful job !
Is that an ABS Power Brake electric power master I see?
And you flipped the throttle body…did that help clear the hood?
944convert- Posts : 253
You appear to like speed density. Is there a reason?
Dawgz83948- Posts : 603
Speed density? There's a MAF in the curve of the intake tube. Blade style.
TB is flipped, made the hood closing possible
Yes , it does have ABS electric brake booster. Much cleaner install than the Hydro that I normally use.
With four CATS and four O2's
No leaky oil lines either! New street oil pan with a screw on factory style filter!
Nice and flat, as flat as I could get them at least!
erod
Admin, is that new oil pan going to be for sale in the near future? i like very much. Great job.
Turb key job
What's the retail price on that job Eric? Any change from 20k?
Very Nice Eric!!
Looks fantastic! Between the great weather and seeing really nice swaps like this is such a great motivator to finish my car sooner rather than later! Its such a bummer driving my Jeep or having my friends pick me up for the local car show visits
Techno Duck- Posts : 447
Great build
Give me some idea on my project
J
J
Diyman25- Posts : 79
Be careful with the ABS Systems Eric. Mine leaks from under the master. Only been on the car for 2 years.
Admin wrote:Speed density? There's a MAF in the curve of the intake tube. Blade style.
zeusrotty- Posts : 444
Wow, that's clean. I wish I had that pan on my car.
robstah- Posts : 352
Adnin:
Did you need to mod the that oil pan vey much?
The photo that shows the mod area (added flat piece) doesn't look like it changed anything but then again I can't see everything in the photo nor do I know what pan you used.
Not asking to devulage any secrets but it sure would be a comfort to know there is a slick fit pan out there for a 944
Nicely done!!!!
Nicely done!!!!
Tehone- Posts : 84
RobotMachines- Posts : 165
They keep looking better and better! Awesome install!
awesome job... looks much better with that in it than when i saw it with the stock motor.
shokwave30- Posts : 68
are those the headers currently on the TPC website? does the stock cross member get reinstalled?
jf951- Posts : 5
looks like it was meant to be there nice job
stu wright- Posts : 312
EROD
Great Job Admin, I'm in California and after reading about the EROD motors and seeing your conversion, even though the motor is a bit pricey. I'm thinking that might be the way to go.
I see your running headers, A no-no here in CA. Did you try the install with the exhaust manifolds that came withe the motor?
mrmartini101- Posts : 8
hi factory manifolds dont work with the steering shaft unless they are moded. There are a few on this site that have had the manifolds shaved to a new angle to make them work.
Thanks I did see that, and also some on the down pipes also. I was just hoping.
» Plug-in 500 HP crate motor
» LS3 GM Performance crate engine conversion P/N CT 525 for 89 951
