Today at 7:48 am by Michael B.
Yesterday at 8:40 pm by VA944LS1
Yesterday at 3:47 pm by kevin924kevin
» New 944 widebody & aero
Thu Feb 22, 2018 6:56 pm by scryfst
Thu Feb 22, 2018 12:23 pm by Murrdog9000
Wed Feb 21, 2018 7:41 pm by 962porsche
Tue Feb 20, 2018 11:58 pm by 948
Tue Feb 20, 2018 1:51 pm by acorad
» Oil Pan question
Tue Feb 20, 2018 10:41 am by Rothaus
» 83' Porsche 944 LM7 Build
Mon Feb 19, 2018 2:39 pm by Jchard944
ls pcv hose
ls pcv hose
Post  cfgioja on Sun May 06, 2012 3:06 pm
Hey guys, i have tracked down an issue i am having with oil consumption and realize the pcv system is hooked up wrong. I need to find a pcv crossover hose the goes from the back driver to back passenger valve cover and y's to the tb.
Anyone know where i can get one?
PCV
Post  fliermike45 on Sun May 06, 2012 3:33 pm
Talk to Xschop, he uses a PCV with a smaller orifice and routed as you mentioned, I think the info is in a thread somewhere here. I use his setup and things seem OK.
Re: ls pcv hose
Post  Rich L. on Mon May 07, 2012 12:19 am
cfgioja wrote:Anyone know where i can get one?
I bought a used one off EBay but the rubber bits were dry rotted to the point that they weren't useable. So I bought a new one from gmpartsdirect.com. The trick for me was to get the 99+ one so it fit the passenger valve cover correctly. The 97-98 style I got the first time didn't fit.
I also installed a catch can and am finding I lose quite a bit of oil through the breather. Your other option would be to do the LS6 valley cover and PCV routing which should cut down on that loss.
Re: ls pcv hose
Post  cfgioja on Mon May 07, 2012 8:37 am
I built one with some 3/8 hose and a tee. Should ork, already feel a difference in the car with the right hookup
Re: ls pcv hose
