» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
No start issue.
No start issue.
Post  zeusrotty on Wed Apr 25, 2012 12:52 pm
My car wont start. It was running, I shut it off, and After I re hooked up the electric booster to the fuse box it wont start. It turns over, but wont fire up. The only thing I did was pull up on the fuse and relay panel to make sure the wires were tight for the electric pump. What could I have screwed up? HELP!
zeusrotty
Re: No start issue.
Post  skywalker01 on Wed Apr 25, 2012 4:03 pm
When you turn the car on (but don't crank it), does the fuel pump run for a couple seconds then shut off?
skywalker01
Re: No start issue.
Post  zeusrotty on Wed Apr 25, 2012 4:05 pm
skywalker01 wrote:When you turn the car on (but don't crank it), does the fuel pump run for a couple seconds then shut off?
Not sure. I will check as soon as I get home from work. I don't think it is though.
zeusrotty
Re: No start issue.
Post  skywalker01 on Wed Apr 25, 2012 6:38 pm
If you don't hear the pump, you have no fuel. I would check for broken wire, blown fuse, or loose relay. Check voltage coming from ECM to fuel pump relay.
skywalker01
Re: No start issue.
Post  zeusrotty on Wed Apr 25, 2012 6:50 pm
I hear a whine under the dash but isnt the pump in the tank?
zeusrotty
Re: No start issue.
Post  skywalker01 on Wed Apr 25, 2012 7:25 pm
I would hope the pump is next to the tank and not in the tank. You should hear the pump toward the rear of the car in any case. Suggest locating the pump and connecting a multimeter to it. You should see voltage briefly after turning the key (but not starting it)
skywalker01
Re: No start issue.
Post  zeusrotty on Wed Apr 25, 2012 8:44 pm
So I plugged in my HP tuner and computer to see if I could locate an issue, and the car started. WTF? Any ideas of what could have happened?
zeusrotty
Re: No start issue.
Post  skywalker01 on Wed Apr 25, 2012 8:53 pm
Dunno - maybe you had some sort of issue that connecting to the ODBII cleared
skywalker01
Re: No start issue.
Post  xschop on Wed Apr 25, 2012 9:39 pm
Is the vats deleted?
Re: No start issue.
Post  zeusrotty on Wed Apr 25, 2012 9:47 pm
I have no idea what that is, or means. I bought this car already built by a guy named Mike at German Performance. Every time I dig into this thing I find something new.
I just found what vats is and I do think that maybe that was my issue. I just have no idea how I fixed it. LOL
zeusrotty
Re: No start issue.
Post  xschop on Wed Apr 25, 2012 10:01 pm
Vehicle anti theft programming. IIRC, SSP wiring said they deleted it from my ECM.
Re: No start issue.
Post  87-944S on Wed Apr 25, 2012 10:17 pm
Since you HPTunrs it is very easy delete VATS. Go to system, general, then security, it should look like this
Change it to none like the screenshot
Re: No start issue.
Post  xschop on Wed Apr 25, 2012 10:17 pm
Just keep in mind that if the GM ECM is getting power from the old Porsche ECM relay, it is a POS and can be further complicated by the factory alarm if there is one. Bypassing the alarm and factory relay should be mandatory or it'll leave you stranded at the wrong time, never fails. Evil or Very Mad
Re: No start issue.
Post  zeusrotty on Wed Apr 25, 2012 10:38 pm
xschop wrote:Just keep in mind that if the GM ECM is getting power from the old Porsche ECM relay, it is a POS and can be further complicated by the factory alarm if there is one. Bypassing the alarm and factory relay should be mandatory or it'll leave you stranded at the wrong time, never fails. Evil or Very Mad
I bet thats what the issue was. How di I bypass all of this. I do also have a factory alarm, and it isnt being used.
zeusrotty
Re: No start issue.
Post  xschop on Wed Apr 25, 2012 10:46 pm
Mine is an 85.5 car with the alarm and using the schematic, I came up with this..... Clark's garage also has a jumper wire alarm delete procedure...
PROBLEM IS BACK... I am lost.
Post  zeusrotty on Sat Apr 28, 2012 1:51 am
And I looked on my hp tuner, It doesn't give me the option to take out the vats. Any , more ideas?
zeusrotty
Re: No start issue.
Post  spence on Sat Apr 28, 2012 7:41 am
I would contact the old owner and get as much info. as possible. That will help you
Re: No start issue.
Post  zeusrotty on Sat Jun 07, 2014 8:36 pm
Bringing up this old thread because I'm suddenly having a no start issue with no fuel to the rail. (Gauged it). Also I tried a new GM fuel relay.
I have noticed a few times that upon acceleration it's been sputtering at higher rpm's, and it did do it earlier today before I started to do a little work.
 All I did was remove the cruise control.... That wouldn't do it would it?
Anyway, I finish the pulling of the cc and it won't start.  It is on the GM FUEL relay, and I don't here the fuel pump spinning up at all when I turn the key.   Any suggestions? Would the pump just completely go out like that with no noise at all?
I should also mention it's the original pump. I'm probably going to just order a new warbro392 anyway, but if that's not it I'm perplexed.
zeusrotty
Re: No start issue.
Post  skywalker01 on Fri Jun 13, 2014 12:45 pm
When you connect battery power to the pump directly, does it work?
skywalker01
Re: No start issue.
Post  zeusrotty on Fri Jun 13, 2014 1:36 pm
I got it figured out. I had a wire come loose. 2 days of frustration.... Ugh.
zeusrotty
Re: No start issue.
