ls pcv hose
ls pcv hose
Hey guys, i have tracked down an issue i am having with oil consumption and realize the pcv system is hooked up wrong. I need to find a pcv crossover hose the goes from the back driver to back passenger valve cover and y's to the tb.
Anyone know where i can get one?
PCV
Talk to Xschop, he uses a PCV with a smaller orifice and routed as you mentioned, I think the info is in a thread somewhere here. I use his setup and things seem OK.
Re: ls pcv hose
cfgioja wrote:Anyone know where i can get one?
I bought a used one off EBay but the rubber bits were dry rotted to the point that they weren't useable. So I bought a new one from gmpartsdirect.com. The trick for me was to get the 99+ one so it fit the passenger valve cover correctly. The 97-98 style I got the first time didn't fit.
I also installed a catch can and am finding I lose quite a bit of oil through the breather. Your other option would be to do the LS6 valley cover and PCV routing which should cut down on that loss.
Re: ls pcv hose
I built one with some 3/8 hose and a tee. Should ork, already feel a difference in the car with the right hookup
