grease for manual rack
I am not sure if ep moly grease will work on a manual rack?
Also is there a grease fitting or do i cram the end with it?
Re: grease for manual rack
The FSM says to fully extend either tie rod and apply (VW AOF 063 000 04) steering gear grease to the tie rods.
So, yeah, (moly is fine) pull back the boots and just apply the grease....
You can pack a bit into the housing to get to the gear but I dont know how to take it apart and the FSM doesnt say how to either. Regardless, there is a small fine-threaded hole (#16 in the above picture) near the bottom, that is used to center the rack for alignment, that you can push some grease into which goes directly to the gear....
Hope this helps.
Hope this helps.
Thanks, that is exactly what i needed to know.
Today at 12:47 am by sharkey
