» Transaxle rebuild
Today at 8:51 pm by yamamtx
Today at 8:27 pm by matt889
» Hello, Gentlemen.
Today at 7:43 pm by rawr
Today at 7:37 pm by Porsche951toLS3
Today at 7:17 pm by Porsche951toLS3
» alignment specs
Today at 12:53 am by sharkey
Any power steering fittings i should save?
Post  Techno Duck on Mon Apr 16, 2012 12:16 am
Was wondering if i should save any of the power steering fittings off the original Porsche system, in particular the ones that attach at the rack? Are they needed for the custom lines to the f-body style pump or should i be able to find fittings for everything. Every line in my PS system is new, so it would break my heart to cut up the lines for the fittings. A friend is buying my long block so i figure i can maybe trade for his old PS lines if need be, otherwise ill just put these up for sale!
PS Fittings
Post  fliermike45 on Mon Apr 16, 2012 6:20 am
FYI...I purchased metric to AN fittings for the steering rack and also a AN fitting for the GM PS Pump.
Remember to use steel fittings and high pressure hose on the pressure side of the system.
Sell or give your old Porsche lines away.
Re: Any power steering fittings i should save?
Post  Admin on Mon Apr 16, 2012 7:39 am
Keep the banjo fitting for the return line. I reuse it as well as the high pressure line. I cut the line just where it starts to head to the passenger side of the car and weld on a male fitting (AN 6 weld nut) makes it much easier to fit you lines later.
Post  Techno Duck on Mon Apr 16, 2012 9:49 am
Ok thanks for the advice guys Very Happy
Post  a951 on Mon Apr 16, 2012 11:24 am
Soo, anyone got a partslist at summit for whats needed? Wink
a951
Any power steering fittings I should keep off the original porsche system
Post  Powerman951 on Mon May 21, 2012 6:13 am
a951,
Did you ever receive a parts list from the Summit for what parts are needed? Shocked
Last edited by 61646572 on Mon May 21, 2012 6:14 am; edited 1 time in total (Reason for editing : grammar)
Powerman951
