» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
oil line recommendation.
Post  dallas on Thu Aug 13, 2009 8:22 pm
Any recommendations on oil lines? Our lines come pretty close to the headers. Anyone not have any problems? What mfg are your lines? The ones I've seen are only rated for 250f. The headers might get them hotter than that.(sitting in traffic) Thanks in adv. Alex
dallas
Re: oil line recommendation.
Post  Admin on Thu Aug 13, 2009 8:25 pm
Use steel braided lines with aluminum fittings, and just slip a protective heat sleeve over the lines as you assemble them. Nobody makes a pre made set of lines. Every car is built a little different.
Post  dallas on Thu Aug 13, 2009 8:52 pm
Steel braided lines come in a variety around here. I stopped at a shop today and they had this steel braided hose you could see light through. It had a clear nylon type tube running down the inside. I didn't trust it. Seems I just ran across This stuff by xrp called hs 79 Its rated at -40 to 400 degrees Gonna check it out. I realize I have to make my own. I'd rather it that way. I like earls fittings ,they seem like they would hold pretty good. I don't trust push on. Had one fail in my boat. Mobil 1 all over the bilge, nasty stuff to clean up.
dallas
Post  m73m95 on Thu Aug 13, 2009 8:58 pm
Make a trip to a hydraulic hose shop. They have hoses for every application that they can cut to length, and put "real" crimped on ends.
Just tell them what you're (we're) doing, and they can point you in the right direction as far as to what type of hose you need.
Also, with oil lines running close to headers. The oil running through the hose keeps the hose cool, so no need to worry about damage to the hose. The oil lines on the turbo's of big diesel trucks are about the same size as the filter hoses on an LS1, and they run from the hot side of the turbo, along the exhaust manifold, 1/2 away at 1200*, to the block. No problems....
m73m95
Post  dallas on Fri Aug 14, 2009 6:15 am
Thanks guys, getting close to finishing up. Can't wait to hear this puppy run. I didn't think about the oil keeping the lines cool. But your right. We use steam to keep a sootblower cool in our boilers at work. A little cooler than the 2500 degree fire.
dallas
