track day oil recommendation?
+2
marc a
hpt951
6 posters
944Hybrids: 924/944/968 and 928 V8 Conversions :: Technical Stuff (other than motors) :: Tracking Your Car
What do all you track day guys use for oil in your LS1's? I'm in the midwest, pretty hot/humid during the track season
hpt951- Posts : 28
Re: track day oil recommendation?
Brad Penn 20w-50
marc a- Posts : 170
Valvoline VR-1 20w50
cjbcpa- Posts : 60
That's really heavy oil guys. Like what you should run in the factory 951 turbo motor.
I run Shell Rotella Synthetic 10w40.
docwyte wrote:That's really heavy oil guys. Like what you should run in the factory 951 turbo motor.
Good point, I should have clarified that I am still running a stock 944 Turbo motor. My conversion is still an engine rebuild away.
CB
cjbcpa- Posts : 60
Amsoil 15W-50
10w40? thats very thin in a hot climate
my favs are 5w50/10w60
a951- Posts : 121
thicker oil = hotter temps
cool, thanks for the suggestions. I ran the 20W50 in my turbo engine but thought it would be too thick for the LS1. A circle track racer I work with suggested the Joe Gibbs oils, they even make a LS1 specific viscosity.
hpt951- Posts : 28
» oil line recommendation.
» Front Spring Recommendation
» Peformance Systems Integration, Vendor Recommendation
