Help, I cannot find a 10.9 or 12.9 m14 x 1.5 x 85mm bolt for the life of me.
So, I am adding coilovers and cannot find the appropriate bolt strength. Checked, Ace, Home Depot, Lowes and Googled online. Any suggestions? I found a 8.9 grade in Mcmasters, but thats it.
any help would be great.
aixgelo78- Posts : 182
Re: Help, I cannot find a 10.9 or 12.9 m14 x 1.5 x 85mm bolt for the life of me.
No idea if you needed partial thread or full thread but here are some results...
Grade 10.9
http://www.metric-threaded.com/detail.aspx?item=9609014090&id=1026
Grade 12.9
http://www.metric-threaded.com/detail.aspx?item=9129314090&id=726
Grade 10.9
Grade 12.9
Heres a few more. 85mm is not showing up. You may want to call these places or cut the 90mm down to 85mm.
Fastenersdirect.net
F-42654
Grade: 10.9
M14-1.50 X 90MM
Fastenal:
M14-1.5 x 90mm DIN 960 Class 10.9 Yellow Zinc Cap Screw
$14.22(1 EA)
SKU: 11114737
M14-1.5 x 90mm DIN 960 Class 10.9 Plain Cap Screw
$8.24(1 EA)
SKU: 11113291
M14-1.5 x 90mm DIN 961 Class 10.9 Plain Cap Screw
$11.91(1 EA)
SKU: 11113435
M14-1.5 x 90mm DIN 960 Class 10.9 Zinc Cap Screw
$10.23(1 EA)
SKU: 11114032
M14-1.5 x 90mm DIN 961 Class 10.9 Zinc Cap Screw
$17.84(1 EA)
SKU: 11114164
M14-1.5 x 90mm DIN 961 Class 10.9 Yellow Zinc Cap Screw
$20.51(1 EA)
SKU: 11114868
Fastenersdirect.net
F-42654
Grade: 10.9
M14-1.50 X 90MM
Fastenal:
$14.22(1 EA)
SKU: 11114737
$8.24(1 EA)
SKU: 11113291
$11.91(1 EA)
SKU: 11113435
$10.23(1 EA)
SKU: 11114032
$17.84(1 EA)
SKU: 11114164
$20.51(1 EA)
SKU: 11114868
Thank you. I guess it is just me. I couldn't find them when I was looking for it.
**edit, I couldn't find any 85mm 90 would do just fine.
aixgelo78 wrote:I guess it is just me. I couldn't find them when I was looking for it.
Not just you. They are truly quite hard to find.
Found some here: http://www.belmetric.com/
belmetric seems to only have x90? and 10.9 not 12.9?
a951- Posts : 121
Try Allen Fasteners. They have tons of stuff as well.
Allen Fasteners
Allen Fasteners
a951 wrote:belmetric seems to only have x90? and 10.9 not 12.9?
yep, I was only able to get a 10.9 from there.
***edit- allen fasteners are cheaper as well
» Where did you find your LS1? I need one :)
» Specs on different GM engines
» How to find the ID for a 944 transmission
