Check engine light
Check engine light
I just used the brake fluid indicator wire (black & yellow stripe) as my check engine light wire. Now when the ECU sends out a ground signal for the CEL light, the (!) light will light up when trouble codes are present. The only thing is the brake fluid light will also come on. Not a big deal to me
Re: Check engine light
Brilliant, have a Guinness. That is way easier than what I have read before.
Damn right.... happy saint patty's day!!
» Check engine warning light
» Engine oil warning light
