Mon Jul 08, 2013 5:56 pm by Admin
Coolant temp gauge...
+4
aixgelo78
8 posters
Drove the car to the gas station today for the first time ever!!! not to mention around the block a few times.
My temp gauge stayed really low, it practically did not move. Is this normal or is it just my car? i remember it working when I first drove the car, Im assuming that the LS1 just runs a lot cooler....
TIA
Chris
TIA
Chris
aixgelo78- Posts : 182
Re: Coolant temp gauge...
Mine stays on the first line while driving and not in stop and go traffic. It gets into the middle area when in traffic. Then it gets near the red when the hose bursts in traffic.
Arthropraxis wrote:Mine stays on the first line while driving and not in stop and go traffic. It gets into the middle area when in traffic. Then it gets near the red when the hose bursts in traffic.
LOL. I just inspected my driver's side hose and it was hitting the alternator making a deep gouge on the brand new radiator hose. Kinda sucks because this damn car holds so much coolant.
My gauge only moved 1/8th of an inch, but my fan went on as it should.
Temp gage
What temp sensor are you guys usuing? I am using a VDO#323421 as specified in sloan's book. It is located using an adaptor fitted in the rear of the passenger side head.
At cruise my gauge needle is level (horizonta)l, in town traffic it moves to a point about half way between horizontal and the upper red line.
Mine is the same sender in the passenger side head, factory fans, LS PCM controlling the Porsche fan relays and a new turbo radiator that has the A/C condenser in front of it. You are in Fl the ambient temp may make a difference.
I've got an Autometer water temp gauge and it basically read 180-190 all the time in traffic. Only time it goes higher is on the track.
Thank you for all the input guys. I am using the same vdo sender as mike, as specified in the manual. At least I know I have a reference point that my gauge is off. I will now try to shop for one.
I will do an autometer gauge later on, I have to catch up on $$$.
Doc, when your autometer gauge shows 190, on what line is the Porsche VDO gauge needle?
Unfortunately I don't know as the factory gauge isn't hooked up...
aixgelo78 wrote:Arthropraxis wrote:Mine stays on the first line while driving and not in stop and go traffic. It gets into the middle area when in traffic. Then it gets near the red when the hose bursts in traffic.
Check out a couple of radiator hose protectors I made out of some stainless (on the left). I recommend doing the same with whatever engine you have in there.
RobotMachines- Posts : 165
Found this:
Is it possible to use a ls1 spec coolant temps while I wait for my vdo gauge sensor to come in?
matt889- Posts : 214
I just used a cheap scan tool I have that does a data stream to keep track of coolant temp till I got my porsche guage to read correctly with the right temp sender.
phlip- Posts : 67
i Will keep That in mind thanksphlip wrote:I just used a cheap scan tool I have that does a data stream to keep track of coolant temp till I got my porsche guage to read correctly with the right temp sender.
on which wire do i plug my VDO sender to the blue yellow or blue green if i have a 1 post sender ( 944 1986 )
I believe it's blue/yellow for the gauge and blue/green for the warning light.
Today at 2:47 am by sharkey
Fri Mar 15, 2024 3:01 am by Raymond-P
Fri Mar 15, 2024 12:28 am by Rond948
Thu Mar 14, 2024 10:38 pm by Rond948
Tue Mar 12, 2024 5:22 pm by dcoutofstep
Tue Mar 12, 2024 4:10 pm by dcoutofstep
Tue Mar 12, 2024 2:12 pm by ndog52
Sat Mar 09, 2024 12:07 am by Rond948
Fri Mar 08, 2024 1:15 pm by dcoutofstep
Wed Feb 28, 2024 3:17 am by Gutterboy
