Early 944 electronics tach?
Anyone have a good way to make the early 944 tach work with the lt1? I have the tach output from the ECM hooked up to my tach but of course it reads high. If you adjust the tach to the correct idle it still shows about 1000K too high at mid range and 2000k high at upper range.
joecitizennn- Posts : 46
Re: Early 944 electronics tach?
You can add a resistor or add a tach convertor from dakota digital... I just bought a tach convertor from dakota digital.
Admin wrote:Do a search, this has been gone over a lot in the past.
I must suck at searching because all I came up with was for the late model cars.
Here is what I came up with.
This is for the late cars, but gives you the general idea, I think.
One problem here is the old site is down, and I've found alot of links to there that pertain to this topic.
laptop_geek- Posts : 230
» Early Tach not working with LS3?
» Early 944 LS fuel pump and tach wiring
» swapping my lt from my 83 to my 85.5- tach help
Today at 9:56 am by ndog52
