Mounting a VSS on a pre 85.5?
+10
jsautomotive
RobotMachines
laptop_geek
marc a
joecitizennn
14 posters
Page 1 of 2
Page 1 of 2 • 1, 2
What is the best and cheapest route to mounting a VSS on an early 944 setup?
joecitizennn- Posts : 46
Re: Mounting a VSS on a pre 85.5?
Get a cam gear from any 944/951 motor and have the middle machined out to fit over the passenger's side inner CV. Make a simple mounting plate. The holes are already tapped into the transmission.
You will need a sensor from a 2002 Camaro with automatic transmission and when the brain gets flashed have the tuner choose auto transmission for VSS. (auto trans has same number of teeth as the 944 cam gear. All you need to do is flatten the mounting bracket that comes on the sensor and drill a hole for the sensor to go through the plate. Use small washers to set gap.
You will need longer cv bolts which can be had from McMaster-Carr.
marc a- Posts : 170
Check out Admin's site, he has a nice VSS kit.
marc a wrote:Get a cam gear from any 944/951 motor and have the middle machined out to fit over the passenger's side inner CV. Make a simple mounting plate. The holes are already tapped into the transmission.
Any chance you remember what length CV bolts you used?
laptop_geek- Posts : 230
I don't recall what length you need, but it's a very standard length. I got some at a local hardware store that had hex heads and fit in the space just fine. I believe i had to cut the clamp off the CV boot, but i haven't had any leakage issues either.
The holes in the transmission side are through-holes, so length isn't incredibly important (if they're a little too long, it doesn't matter).
I'll dig out the box in the morning.
marc a- Posts : 170
joecitizennn wrote:What is the best and cheapest route to mounting a VSS on an early 944 setup?
Best cheapest route would be to buy a $99 GPS to mount on your windshield. The good thing about this besides telling you your speed is that it's a GPS with maps and directions with a female voice telling you where to go
RobotMachines- Posts : 165
RobotMachines wrote:joecitizennn wrote:What is the best and cheapest route to mounting a VSS on an early 944 setup?
My speedo works fine, my computer just needs to know how fast I am going. Not sure if I want another female voice telling me where to go.
1.25 x 60 Blue class 12.9. Socket head cap screw. Part number: 91303A207 @ McMaster-Carr
After installation check clearance between bolts and tranny case by spinning wheel slowly 360 degrees.
I forgot to mention, the machine shop should drill the holes to match the CV bolt holes as well.
marc a- Posts : 170
joecitizennn wrote:RobotMachines wrote:joecitizennn wrote:What is the best and cheapest route to mounting a VSS on an early 944 setup?
Well, I have my old 83' 944 lawnmower engine about 15' from where I'm sitting. I can pull the cam gear if you want.
EDIT: No charge, just pay shipping.
944 engine
Hi Robot,
What do you want for the cam tower off your engine?
Mike
Mike
pretty sure I have a spare gear out in the shed from a 944 engine that blew up years ago. If not I will give you a pm.
Mike,
I'm picking up two cars tomorrow, one is a parts car. Engine fire. If you want the cam tower just pay for shipping and it's yours.
VSS
I have asked this question on LS1 Tech and asked the Techs in my shop. and have heared yes you need it, and no it isnt necessary. My car is a 83 944 manual trans, the wiring harness is 98 camaro SS manual trans car. If i have to have it thats fine, I have an extra cam gear to use for the reluctor, but if i really dont need it id rather not have to run the extra wiring to the back of the car. thanks.
jsautomotive- Posts : 14
jsautomotive wrote:I have asked this question on LS1 Tech and asked the Techs in my shop. and have heared yes you need it, and no it isnt necessary. My car is a 83 944 manual trans, the wiring harness is 98 camaro SS manual trans car. If i have to have it thats fine, I have an extra cam gear to use for the reluctor, but if i really dont need it id rather not have to run the extra wiring to the back of the car. thanks.
From what I understand:
Some people have been able to run this for a short amount of time without having problems, but I think most everyone has eventually hooked it up. The car will run without the VSS installed, but drive-ability will suffer. I think the biggest issue is having trouble idling and taking off from an idle. I found a more detailed explanation on one of the swap sites. Let me see if I can find it.
It's just a single pair of wires. Don't be lazy.
robstah- Posts : 352
lt1swap.com wrote:VSS - You should KEEP a vehicle speed sensor regardless of what transmission type you use. The PCM needs to know if vehicle is moving. Without the speed sensor, you can suffer from reduced fuel economy, reduced power, and idle problems. There are a few options for speed sensors on the transmissions with cable drive output. View this link at Dakota Digital website. I have used Dakota Digital SEN-4160 with good success. This is a 8000 pulse per mile sensor, that will allow cable speedometer hookup. I can program any PCM to accept any # of speed pulses.
Here is a discussion that took place not too long ago,
and one that took place at the beginnings of this forum.
Is there a part number for the sensor I can use?
Dawgz83948 wrote:I don't know if this came up before but the VSS sensor that can be used (at least for LT1's) is out of a 1995 Chevrolet Truck C1500 1/2ton P/U 2WD 5.7L TBI 8cyl. Duralast P/N SU1217 $44.99 or Standard SC86. That is all.....
joecitizennn wrote:marc a wrote:You will need a sensor from a 2002 Camaro with automatic transmission
Go to Rock Auto and look up the above car with automatic transmission.
STANDARD MOTOR PRODUCTS Part # SC90 {Click Info Link for Alternate/OEM Part Numbers}
w/ A.T. $17.40
ACDELCO Part # 2131701 {#10456520, 213328, 24225896}
SENSOR,VEH SPD w/4-SPD AUTO TRANS(M30); BOLT ON W/BRACKET $17.41
marc a- Posts : 170
I now have the cam gear and the 2002 camaro VSS on my workbench. Question, is the 2002 VSS compatable with the 1995 LT1 pcm. The PCM is for a caprice automatic.
Second question, The VSS that came with my wiring harness has a different plug than the newer VSS takes. I have the correct plug in my parts bin but It will have to be spliced in. Are the two wires specific in function or can they be swapped?
I'm sorry but the fact that you are dealing with a LT rather than a LS escaped me. Can't help with the LT.
marc a- Posts : 170
Has anyone cut their cam gear in 1/2 (or perhaps 1/3's even) so that you don't have to get it over the CV when mounting and removing it from the axle?
acorad- Posts : 697
I was wondering the same thing.joecitizennn wrote: Are the two wires specific in function or can they be swapped?
They are not interchangeable on the LS series. One is the low signal(Lt Grn/Blk) and the other is the high signal(ppl/white).
marc a- Posts : 170
Page 1 of 2 • 1, 2
Page 1 of 2
Today at 9:56 am by ndog52
