» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
Porsche AC Compressor low mount w/LT1
Post  jerhofer on Fri Mar 02, 2012 9:15 pm
I recently purchased a project 968 with a LT1 motor. When starting the car, there is serious squealing from the serpentine belt area. After my son listened a bit, he was pretty sure the sound was coming from the compressor. He then noticed that the compressor pulley was mis-aligned. We measured and bought a shorter serpentine belt to run everything but the compressor. No squeal. After reading the records that came with the car, I discovered that the compressor mount had broken and had been repaired by the previous owner's favorite mechanic. It is pretty screwed up.
Where would I find a new mount for this application?
jerhofer
http://www.jerryforthofer.wordpress.com
Re: Porsche AC Compressor low mount w/LT1
Post  gamman on Mon Mar 05, 2012 9:32 pm
Jer, I sent you a pm on the other board, and just bumped a PCM for sale that you may want to look at.
Welcome, by the way.
gamman
