firewall plate EmptyYesterday at 6:12 am by Colibri Green
» NDog52's 1986 NA 5.3 Build
firewall plate EmptyTue Mar 26, 2024 6:28 pm by Raymond-P
firewall plate EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
firewall plate EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
firewall plate EmptyTue Mar 26, 2024 8:49 am by 948
firewall plate EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
firewall plate EmptyWed Mar 20, 2024 1:17 pm by Rob44
firewall plate EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
firewall plate EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
firewall plate EmptyTue Mar 12, 2024 12:12 pm by ndog52
firewall plate
+5
skywalker01
stu wright
9 posters
firewall plate Empty firewall plate
Post  kevin924kevin Mon Feb 27, 2012 9:48 am
Does anyone still make the plate for the fire wall. I need to reinforce my 924, but neeed to add for hydrolic clutch slave hole.
firewall plate Empty Re: firewall plate
Post  stu wright Mon Feb 27, 2012 5:27 pm
i believe xshop does
stu wright
stu wright
firewall plate Empty fire wall plate
Post  kevin924kevin Mon Feb 27, 2012 8:15 pm
Thank you, i will check with xschop.
Post  xschop Mon Feb 27, 2012 10:02 pm
I have never made a firewall plate that included the Clutch MC area. The plate has to be angle inset or you'll frag the MC quick as it will bind at the plunger seat.
Post  kevin924kevin Tue Feb 28, 2012 12:23 pm
So does anyone make a proper plate, or am i back to doing it myself. Does anyone have a firewall that i could get so i can deal with the issue at hand.
Post  skywalker01 Tue Feb 28, 2012 2:05 pm
I really don't know if the plate is really a solution to the problem, as the stress will be relocated to the weld along the wheel well (where I have a crack)
skywalker01
skywalker01
Post  xschop Tue Feb 28, 2012 2:28 pm
A firewall plate and a brace to the strut tower would be the fix-all.
Post  Arthropraxis Tue Feb 28, 2012 3:33 pm
Koklen made a clutch MC brace that fit over the mounting studs with a rod over to the strut tower. The mount on the strut tower bolted to the shock mounting screws.
Post  kevin924kevin Tue Feb 28, 2012 4:00 pm
I think the best solution is to find that section of the firewall and have it duplicated with the proper angles for the two slave cyliders. Use a 1/16" plate, drill a series of holes to allow spot welding to the middle areas of the plate and stitch weld the perimeter, so as to try and avoid stress cracks.So who has a wrecked 944 i could buy that section of fire wall from or does anybody have the template for the one i see here all the time. I think it could be modified to allow both slaves to sit correct. Just throwing it out there.Thanks all.
firewall plate Empty Plate
Post  fliermike45 Tue Feb 28, 2012 5:57 pm
While you are doing this, please design a plate that allows a Mustang hyroboost to be used. I will buy one if someone will make them.
PS I'm using Sloan's plate which covers the brake and the clutch portions of the firewall. It is bolted and bonded to the firewall, I'm using spacer washers to angle the brake master cylinder but the stock clutch MC fits flush with the plate.
Post  xschop Tue Feb 28, 2012 9:44 pm
1/4" 2000 series aluminum alloy...stronger than 1/8" steel across the plane Cool
Post  kevin924kevin Wed Feb 29, 2012 9:18 am
So, could we mill a proper firewall plate from alum with the proper angles for the two slaves, and then bolt and bond. What kind of bracket do we need to incorp to allow Hydoboost. Can some one supply a pic. This is something i want to put on my car aswell. I like power brakes.
Post  shokwave30 Thu Mar 01, 2012 7:57 pm
im not sure what the other hydroboost bolt patterns are but the one im looking into uses a GM 3.4x3.5 pattern. what are the others use for bolt patterns?
shokwave30
shokwave30
Post  kevin924kevin Thu Mar 01, 2012 10:06 pm
I am not sure of any of the bolt patterns, we need to find out all and maybe a universal adapter can be made.I think if i could find a proper template as my car will not work for this, i could have a wedges milled to set proper angle for both slaves for a cheaper method and for those who have plates, and have a plate milled to duplicate the factory firewall bond and bolt, just need the info.
Post  marc a Thu Mar 01, 2012 10:26 pm
I just had the plate copied today and will have the computer file that was used to cut the plate tomorrow. PM me if you want the file. Shop says anyone using a laser cutter or waterjet should be able to use the file.
marc a
marc a
Post  marc a Thu Mar 01, 2012 10:40 pm
xschop wrote:A firewall plate and a brace to the strut tower would be the fix-all.
R,
You posted a picture of your brace at one point, and I can't seem to find it. Can you repost it or point me to the right thread.
Thanks!!
marc a
marc a
Post  kevin924kevin Thu Mar 01, 2012 10:41 pm
marc a thank you. I have sent you a pm.
Post  stu wright Sat Mar 03, 2012 7:57 am
anyone got a pic of xshops firewall plate for master cylinder installed with manual brakes to give me some ideas on installing mine that i just got.my master is going to be a tight fit .i was looking in previous brake posts and could seem to find a pic .thanks
stu wright
stu wright
Post  944-LT1 Sat Mar 03, 2012 12:26 pm
Heres all the pictures of the plates that the forum seems to have left. The first is of the brake master reinforcement plate and the second is of the brake and clutch master reinforcement plate.
Post  stu wright Sat Mar 03, 2012 4:10 pm
.with my tall valve covers the only master that looks like it will fit is the wilwood 250 -7563. the resivor on the stock style master interferes with the valve covers .the ls style motors look like they have a little more room in that area . was more interested in sombody running a lt1 with a manual brake setup to see how they have it mounted .remote res seems to be my only choice . i know you are running an ls3 in yours now but you did have an lt1 when you first built it.with stock short valve covers my original porsche master cleared the valve covers but my new motor has tall ones to clear stud girdle and roller rockers.i recently got one of xshops firewall brake master plates and im in process of installing it and have experimented with a couple different master cyl but they dont fit in that small space . almost looks like it needs to move a little towards where clutch master goes.which i dont use because its an automatic. i do very much thank you for your feedback as it was helpful
stu wright
stu wright
Post  kevin924kevin Sat Mar 03, 2012 5:29 pm
I thank you as well, this info will help in the process.
