» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
Wilwood clutch master died WAY too soon!
Page 3 of 3 Previous  1, 2, 3
Re: Wilwood clutch master died WAY too soon!
Post  Arthropraxis on Wed Jun 20, 2012 10:25 pm
Would a new Porsche MC have enough throw for the C5 slave? You have me worried, I feel a clicking in mine intermittently.
Post  Porch on Wed Jun 20, 2012 11:59 pm
Arthropraxis wrote:Would a new Porsche MC have enough throw for the C5 slave? You have me worried, I feel a clicking in mine intermittently.
When they're new the stock ones are pretty marginal, but they'll work. I believe stock is 3/4", mine is a 7/8".
Once they start to wear, the stock ones won't cut it.
Clutch MC
Post  fliermike45 on Thu Jun 21, 2012 6:26 am
FYI, I'm using my original stock MC with the C5 HTOB without any problems....yet.
But then I only have a stock clutch plate set up, no uprated stuff.
Post  Howell944 on Sat Jan 26, 2013 8:36 am
Rich L . I like the look of your floor mount solution. Any details??
Howell944
Post  Rich L. on Sat Jan 26, 2013 10:38 am
Lots of details here:
FYI, this moves the driving position 4" rearward. Only worked with my cage because I'm 5'8". My 6' buddy cannot drive the car.
Post  Howell944 on Mon Jan 28, 2013 6:25 am
I'm only 5'9, Did you have to adjust the steering wheel and gear lever ?? Thanks for the link..
Howie
Howell944
Post  Rich L. on Mon Jan 28, 2013 1:31 pm
Yep, I added a quick release and 1" spacer to the steering column, moved it back about 4" total. I tried just adjusting the shifter but 5th gear was still a reach. I'm in the process of swapping the tranny and rebuilding the whole shift mechanism front to rear. This includes an extended shift lever bent rearward to reduce the reach. I'll post pics when it's all done.
Post  Lemming on Mon Jan 28, 2013 1:37 pm
Howell944 wrote:I'm only 5'9, Did you have to adjust the steering wheel and gear lever ?? Thanks for the link..
Howie
This will also depend on how your cage was built. I'm the same height as Rich, but my cage is to far forward for this mod.
Post  DJ. on Sat Sep 07, 2013 10:20 am
Reviving this thread, has there been any solution to these clutch master problems? Im about to tackle this and I want to do it right.
DJ.
Clutch MC Mount
Post  Dan J on Mon Nov 18, 2013 5:10 pm
Hi guys,
I've started working on my car again, and one winter project is dealing with the clutch MC mount.  Based on my experience burning through a couple aluminum Wilwood MC's, and seeing what others have come up with, I had a couple of mounts fabricated by a local machine shop.  This is designed so the Willwood MC can be mounted straight up, vs on it's side, and it incorporates the angle.  I use a firewall mounting plate as well.
I will report back on how this works once the car is finished. I pulled the motor in order to have room to do this project, and 'while you're in there' projects mushroomed, including a TT rebuild, plumbing new oil coolers for both the trans and motor, rewiring the motor so it's a bit more sano, fresh LS6 heads...and on and on.
It's great to see all the new projects people have built up over the past couple years.  Super impressive!
Dan J
Post  money pit 951 on Tue Nov 19, 2013 9:11 am
Nice adapter! Looks well done. What did they charge you for that?
money pit 951
Post  Dan J on Tue Nov 19, 2013 9:46 am
I found a machine shop that did 2 examples, one in steel, and one in aluminium. The total was about $300. If it works well, I'll post the design here.
Dan.
Dan J
any update on this?
Post  uzriha on Mon May 04, 2015 2:26 am
how is the adapter so far?
would it be possible to share the design? Smile
uzriha
Post  Dan J on Mon May 04, 2015 9:37 am
So far so good. I've only put 100 or so miles on the car since installing the adapter though.
I think there's 2 parts to this. Reinforce the firewall so it doesn't flex. Position the MC at the right angle so the bore is lined up with the throw of the pedal and shaft.
I'll scan and post my drawings - which are basically on the back of a cocktail napkin.
Dan.
Dan J
ok!
Post  uzriha on Fri May 22, 2015 10:09 pm
thank you very much Smile
uzriha
