HOW TO: LS1 Returnless Fuel System
If you have an LS1 with the returnless fuel system and a car with a return system, the following instructional shows how to adapt the returnless system.
A 2000 Corvette fuel filter incorporates a fuel pressure regulator.
It also may be found at your local auto parts store.
The Item# at Napa is FIL3737, and costs around $30.00.
Height (Inches):5.755
Height (mm):146.18mm
Inlet Size (Inches):3/8
Return Size (Inches):5/16
O.D. (Inches):2.23
O.D. (mm):56.64mm
Napa also sells the 12" line (with push style connectors on each end) that connect this filter and the stock fuel line to the LS1.
The filter has a 3/8 inlet port and a 5/16 return port on one side, which will be fastened to the stock Porsche hard lines with compression fittings. Connect the 12" line to the OUT TO MOTOR side, and plug the OEM rubber fuel line into the line and up to the rail.
filter/regulator - $30
12" fuel line repair pipe with push on flares - $10
2 x 3/8 hard line compression fittings - $5
1 5/16 hard line compression fittings - $3
__________________________________________________________________________
The NAPA part for the 12" line is: BK 7304931 and can be found here: [You must be registered and logged in to see this link.]
Fuel Filter/Regulator: [You must be registered and logged in to see this link.]
12" 3/8 line: [You must be registered and logged in to see this link.]
O.D. (Inches):2.23
O.D. (mm):56.64mm
gt1scca- Posts : 795
