» Oil Pan question
Today at 7:39 am by Hotrodz of Dallas
» 83' Porsche 944 LM7 Build
Yesterday at 1:39 pm by Jchard944
» Throttle body question
Yesterday at 12:02 pm by Rothaus
» Posche 924 Audi 4.2 V8 ABZ
Yesterday at 11:25 am by Ralphhh
Yesterday at 10:04 am by kevin924kevin
Sun Feb 18, 2018 8:05 pm by 948
» Magnuson supercharged car?
» WTB: LS powered 968
Found oil pan
Found oil pan
Post  nasomi on Sun Feb 19, 2012 7:38 pm
I was looking around and came across the Moroso 20140 oil pan, which looks alarmingly like the one for sale on renegade hybrid site. It says it's fit for the LS1. Does anyone know anything about the fitment of this pan?
I've been looking for exact dimensions but I've yet to be able to find anything.
nasomi
Re: Found oil pan
Post  Arthropraxis on Sun Feb 19, 2012 7:43 pm
Yes, that is the one to use. It still has to be modified.
Re: Found oil pan
Post  nasomi on Sun Feb 19, 2012 7:54 pm
Thanks, could you elaborate a bit on how it needs modified?
nasomi
Re: Found oil pan
Post  Arthropraxis on Sun Feb 19, 2012 8:23 pm
Here is and example. Make sure you get or do a good welding job.
Re: Found oil pan
Post  nasomi on Sun Feb 19, 2012 9:46 pm
perfect, thanks!
nasomi
Re: Found oil pan
Post  Admin on Mon Feb 20, 2012 7:41 am
Not only does it have to be modified, it does not come with a pick up tube nor does it come with any good baffles in the pick up area.
Re: Found oil pan
Post  948inVA on Mon Feb 20, 2012 11:12 am
Yeah, not sure why you wouldn't just use the TPC oil pan.. the work has already been done for you and will probably end up costing the same.
948inVA
Re: Found oil pan
Post  nasomi on Mon Feb 20, 2012 12:13 pm
A couple reasons. I'm trying to minimize costs, and increase my skillsets. I figure I can buy a pan, a couple sheets of aluminum, and practice welds. I've welded steel before (years ago) and could make a nice bead, however I've never done it with aluminum, and once I add that skill to my list, it makes it possible to do a lot of other things. I've also never created my own parts before, only replaced broken parts with OEM parts from a factory, so I'm hoping to get over the hump of having never done it, to learning how to do it. Sure I might only save a couple bucks, or end up spending a couple extra bucks, but then I have a practical product that I learned how to make.
The whole conversion is a learning process for me, and I want to get as much knowledge and skills out of it as I can. I could buy it all and bolt it on, but then I wouldn't have learned how to do it myself.
nasomi
Re: Found oil pan
Post  Arthropraxis on Mon Feb 20, 2012 4:51 pm
That pan is steel, not aluminum.
Re: Found oil pan
Post  eclou on Mon Feb 20, 2012 6:15 pm
the TPC pan has a very nice baffle design. So far on track the typical high G force left handers have not dropped my oil pressures. This TPC designed pan may save you from having to buy expensive baffles and an Accusump if you plan on doing any track events.
eclou
Re: Found oil pan
