Best place to tap "key on" power?
What is the most preferred place to tap 12v for the ECM power supply? I have my fuse block for the engine management system located under the dash beside the stock 944 fuse block, but have been unsure of where best to tap the power to my box. Want to be sure it can carry the load. Any suggestions?
joecitizennn- Posts : 46
Re: Best place to tap "key on" power?
What year model? Most of the time I get them at the key switch and run it to a relay that then powers the rest of the ad on fuse block for the harness.
Key on power (switched +12 volts)
Simple way to get +12 volts switched power at Pin 1 of the late 944 14 pin connector is to jumper the two wires (black and green) that originally fed power to the ignition coil. This avoids using Pin 3 of the same connector as pin 3 receives its supply through the DME relay which can fail and strand you .
Works for me on my 88 NA 944. After doing this you can remove the DME relay.
Car is an 87 924s, in other words it runs early 944 electronics. I built my own harness from caprice harness parts and it is strictly stand alone. It only draws power for ignition, fuel, sensors, and emissions excluding smog. What type of relay would work best. BTW I have hot wired it for a test and it runs absolutely awesome. This car is very close to done after only two months.
I used one of these on the radio fuse spot:
Works fine and I didn't have to modify anything on the electrical side of the car.
robstah- Posts : 352
Load
Robstah,
Did you do a load analysis on that circuit, is it man enough for the job???
Just checking.
Just checking.
robstah wrote:I used one of these on the radio fuse spot:
Since I am running early 944 type electronics that will not work. The fuse box is under the dash and the fuses are cylindrical. I am a little leery of trusting the entire engine management, coil and injectors included to something so small.
joecitizennn wrote:robstah wrote:I used one of these on the radio fuse spot:
It's to power a relay.
what amperage of relay did you use?
joecitizennn wrote:what amperage of relay did you use?
I ended up using a Ford 30A relay that has either a diode or resistor in it. I used [You must be registered and logged in to see this link.] for the fuse and relay block and followed the image made by xschop for the rest.
» oil pan options
» I don't know if this is the right place for this post (good deal content inside)
» Which relays?
» Which relays?
