RH Alternator mount question
Anyone on here happen to know if the pass frame rail or the valve cover have to be dented in to fit the RH converted camaro alternator/ps bracket?
kstuart- Posts : 1
Re: RH Alternator mount question
I had to dent the top of the valve cover just a little for mine to clear, I did not use the RH bracket exactly, I made a really close copy and use the small alternator.
Today at 12:47 am by sharkey
