why me??? this isn't supposed to happen!!!
time for something else to go wrong with my conversion...this is definitely not supposed to happen on a new alternator...lucky i have a 1 year warranty so i can get a new one for free...but i'm going to go ahead and buy a new Powermaster, maybe it will last better.....
v8944- Posts : 211
Re: why me??? this isn't supposed to happen!!!
Major thing with the LTx engines is to make sure your belt is not crazy tight and I always run a brace from the back of the alt to a manifold stud, much like the factory. Might have to do a little fab work but it is pretty easy.
944v8inDFW- Posts : 147
cheesy
If it was cast in Mexico, the alloy and process is sh$tty. Dodge truck rims are being recalled for the same defect.
hmmm i wouldn't be surprised if it was cast in mexico...
about the mount, i actually have an Alterstart Systems 227r low mount alternator bracket that i had it mounted on...and i think the brackets on the alternator were wrong (they probably sent me a 7860 instead of a 7861 because the brackets were flipped...the thick one was where the thin one was supposed to be...) i will look into fabbing up an extra support bracket.
v8944- Posts : 211
actually did the same thing to the porsche alternator, I was kind of wrenching on it with a crowbar tho
Tetzuoe- Posts : 178
haha, yeah that'd probably do it!!
v8944- Posts : 211
Today at 12:47 am by sharkey
