Motor Pulled!!
Motor Pulled!!
Well....we finally got the motor pulled out today! Not bad for a weekend off. I'll try to post some pics later on. Now I gotta get these parts and engine sold so I can get my kit.
the951racer- Posts : 135
motor pulled
Now is the time to clean and do a meticulous job painting the engine compartment.Later on in the project you will be glad you did. Good Luck.
ROGUE S2- Posts : 35
Re: Motor Pulled!!
ROGUE S2 wrote:Now is the time to clean and do a meticulous job painting the engine compartment.Later on in the project you will be glad you did. Good Luck.
My thoughts exactly. I think I will be rolling her out this week to start that. Just gotta remove the harness from the firewall. Any tips?
motor pulled
Go ahead and remove the DME and the 944 harness they will not be used anyway.
Re: Motor Pulled!!
Hopefully I can get that done as well as cleaning and painting the engine bay this week. Thanks goodness for an unnderstanding wife.
Re: Motor Pulled!!
the951racer wrote:ROGUE S2 wrote:Now is the time to clean and do a meticulous job painting the engine compartment.Later on in the project you will be glad you did. Good Luck.
When you remove the harness, save the large rubber grommet, you will need this for the new harness. I also saved the 14 pin plug (LH engine bay) with lengths of wire, take a look at the below link for connections you need for the conversion.
pormgb- Posts : 186
Re: Motor Pulled!!
Thanks a bunch man. I cannot express how grateful I am for this forum and the great group of folks on it!
