Mystery brass fitting.
I filled my cooling system and have a minor drip from this brass fitting located in the crankase behind the starter motor. Can someone please identify it and what's it's use? Thanks.
Block drain
Had a closer look this evening.
Main brass plug screwed into the block has a smaller plug (approx 3/8") screwed in to it.
This was loose and causing the drip.
Question is: The inner plug has two small nuts on the end, is this a transducer with a place for a terminal?
Last edited by fliermike45 on Fri Aug 26, 2011 9:15 pm; edited 1 time in total (Reason for editing : typo)
Re: Mystery brass fitting.
Kinda looks like a temp sensor doesnt it?
Pretty wild looking starter, what kind is it?
Starter
And that starter was too large in diameter, would not allow the RH headers to fit tight to the head.
Swapped it out to a stock sized starter.
» Drive shaft too short to reach pilot bearning
» Mystery black box
» Mystery Plate - do I need this thing??
» Mystery black box
