» Fuel tank over pressurizing
» LS Conversion Kit Plus
» tips on removing headers?
» Oil Pressure
» Mass oil leak!?
» SBC Pilot Bearing
» Lighten clutch pedal feel?
February 2019
bell ranger helicopter engine
Post  stuart f. wright on Thu Jan 19, 2012 7:46 pm
it works on the y2k superbike its size is amazingly small but makes incredible power from 185 pound jet tourqe is smular to a diesel truck engine
Last edited by 944-LT1 on Thu Jan 19, 2012 9:45 pm; edited 3 times in total (Reason for editing : Had to fix the link.)
stuart f. wright
stuart f. wright
Re: bell ranger helicopter engine
Post  spence on Thu Jan 19, 2012 7:59 pm
That link brought me to Jimi Hendrix on youtube?
I found another [You must be registered and logged in to see this link.]
Post  stuart f. wright on Thu Jan 19, 2012 8:06 pm
sorry bout that spence i fixed it look at link now i believe lenos bike uses a bell ranger motor .tourqe is amazing 450 ft pds plus. the link i reposted is of the Y2K superbike. its size would fit nicley in a 944.if it can fly a 3000 pd aircraft im sure it could move a car
stuart f. wright
stuart f. wright
Post  spence on Thu Jan 19, 2012 8:32 pm
wow thats cool!! 185,000$!!! lol
There's still something wrong with the link though.... I fixed it below
Post  stuart f. wright on Thu Jan 19, 2012 8:38 pm
i found a 928 with a jet turbine too
stuart f. wright
stuart f. wright
Allison C250
Post  fliermike45 on Thu Jan 19, 2012 9:49 pm
The Bell Jet Ranger engine originally designed and built by Allison and now owned and built by Rolls Royce.
After watching the bike video I had some misgivings, the helio depicted is a Huey and not a 206 Jet Ranger as described and the guy tells us that the max torque is at 2000 rpm. The engine is rated at 35,000 rpm power turbine speed and the output shaft turns at 6000 rpm. So his bike must have a gearbox to further reduce the speed to 2000.
Depending on model dash number the engine is rated from 420 to 715 horsepower.
Guess comeone is going to have to make hybrid Porsche/Rolls Royce badges.
Post  944-LT1 on Thu Jan 19, 2012 9:53 pm
What....no thrust vectoring? Meh..... Laughing
Post  stuart f. wright on Fri Jan 20, 2012 7:10 am
very good digging mike thats the therory i came up with the rpm would have to be reduced.hot rod magazine had a article a while back on a chevy pu with a turbine helicopter engine in it and was talking about using a brake to slow the engine to engage into gear and the trans it was hooked to was a gm turbo 400 .rolls royce porsche badges .haha .still an interesting concept a 185 pound motor making that kind of power wow
stuart f. wright
stuart f. wright
Turbine cars
Post  fliermike45 on Fri Jan 20, 2012 8:28 am
If one goes back in history, Rover built prototype gas turbine engine cars and took the development to the race track. The Rover powered BRM ran at Le Mans in the early 60's, it has a single speed transaxle and aimed at efficiency awards. I believe the problem with turbines is that they really have to run at constant engine speed to develop the required power. The STP car at Indy proved this also.
I'm sure that if turbines were viable race car engines the racers would use them. Putting one in a road car or bike is really an impractical gimmic.
Post  parttimegearhead on Fri May 09, 2014 7:31 pm
Great for drag racing and car shows but that's about it. Iv ridden in helos almost every day for the last 8 years with my job. Fliermike45 is correct on the engine needing consistent speeds. Throttle response is sluggish due to the way a turbine works.
parttimegearhead
