» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
Late turbo front on early n/a?
Post  jayman1869 on Tue Jan 10, 2012 12:35 am
Anyone on here ever put a late model turbo front bumper on a early N/A car. I want to have that clean looking front to include the slit to help the LS1 breath once she's in.
What all is entailed with the swap. Complete fender and bumper swaps or just the bumper?
jayman1869
Re: Late turbo front on early n/a?
Post  944-LT1 on Tue Jan 10, 2012 1:08 am
Ive done it but with the Kokeln GTR bumper and on an 87. I had to change to turbo front fenders and buy a turbo bumper support. I think thats about it besides maybe the headlight sail panels but Ive never confirmed that; I have TPC fixed headlights.
This may not help much but....it can and has been done!
Post  jayman1869 on Tue Jan 10, 2012 9:42 am
Headlights shouldnt be an issue because I too will be doing the fixed headlight conversion.
Thanks for the info.
jayman1869
Post  962porsche on Fri Jan 20, 2012 4:21 pm
i have done many . you need the fenders and the bumper along with the hardwere for said parts . other than that it's just a matter of removing the old and bolting on the later parts . about a 6 to 8 hour job . to a newbee add 3 or 4 more hours .
962porsche
Post  jayman1869 on Fri Jan 20, 2012 4:35 pm
962porsche wrote:i have done many .....about a 6 to 8 hour job . to a newbee add 3 or 4 more hours .
OUCH!!!!
hahaha
jayman1869
Post  pormgb on Fri Jan 20, 2012 4:58 pm
If you are mechanically inclined you can convert your N/A fenders, you can trim N/A fenders to match a turbo bumper cover. I've done this conversion by making a card board template then trimming the fenders with a cut off wheel. If you cut carefully you will only have to dress the cut ends, you could also roll the ends but this will cause the paint to crack.
To support the turbo front end, you will need the following parts;
-Turbo Bumper Shocks
-Turbo Bumper Cover support (aluminum bar that mounts on bumper shocks)
-Turbo Head Light Covers
-Turbo Nose Panel
-Some rewiring to support turbo fog and driving lights
There are pictures gallery of the conversion in my gallery (pormgb), the right side still needs some work because the fender was damaged and repaired.
pormgb
Post  jayman1869 on Fri Jan 20, 2012 8:35 pm
sweet.. I'll check it out.
I want to swap it over so it gives it a cleaner look as well as when I put in this LS1, I can have the filter go straight and that way I can have hair flow straight through the bumper to the filter!
jayman1869
Post  luginbuhlj on Thu Mar 01, 2012 3:12 pm
i just got the turbo s front swap with lindsey vented nose, bolted right up mostly besides a couple brackets for the front bumper and fender since it was an 87 na
luginbuhlj
Post  gamman on Mon Mar 05, 2012 9:55 pm
luginbuhlj wrote:i just got the turbo s front swap with lindsey vented nose, bolted right up mostly besides a couple brackets for the front bumper and fender since it was an 87 na
This is what Eric needs to do once he has cloned himself.
gamman
