Warning, Warning, Warning
I bought a oil filter relocation kit from sloan, it used Push Lok fittings an 240 psi hose.
Driving back from the exhaust shop I got an oil light and no oil pressure.
Today I got the car on the lift and found the filter return line off its fitting. I could easily push the hose on and pull it off again. It's close to the exhaust, must have cooked.
New oil and temporary clamps, back on the road.
Braided hose and fittings on order, ditch this push on stuff.
Re: Warning, Warning, Warning
CONFIRM, CONFIRM, CONFIRM
Also the alloy Twist-On fitting are crap. The Stainless braid does not allow the threading to compress the inner polymer lining properly......If you use braided stainless or push-on also use hose clamps.
Though those Push Lok fittings are not ideal, when installed correctly they should work just fine for stock oiling systems. Dozens of vendors sell a Push Lok type relocation kit for the LS1. (I also would suggest an Oetiker clamp or fuel injection clamp as added insurance.)
Do you think heat from the exhaust could have softened the hose enough so that it could slip off? I have a wrap around heat shield in that area to protect the oil lines.
BTW, I am using the taper tread on fittings with SS braid. As Xschop mentions, they are a pain to get installed correctly but very robust when done so.
948 wrote: (I also would suggest an Oetiker clamp...as added insurance.)
me too
944convert- Posts : 253
