OBDII wiring harness?
I have a 1997 lt1 that I need a computer and wiring harness for. Question is, can you use an earlier OBDI wiring harness and computer, or will the plugs not match the later OBDII motor?
joecitizennn- Posts : 46
Wiring question
Call SSP Wiring 928-460-0764, They modified my 88 harness, very helpful guys.
Re: OBDII wiring harness?
so since this is a thread for ltx conversions, what are most of you running obd I or II?
I'm running obd1, after some research the harness is shy 1 pin to become obd2. The ecu's are different (from what I've been told)
here is a few links where i got my info from
msmoorenburg- Posts : 75
I have an oppertunity at a obd1 harness and computer, but I am scared of it because my engine is obd2. Im afraid that some of the sensors will be non compatable and I have not been having much luck with internet searches. The engine is ready to be fired and I am getting tired of looking at it every night and not being able to continue with the project.
