Round to Square, sealed beam connections.
I removed my motorised headlights and installed a pair of TPC rectangular light buckets.
The pin connections on the rectangular sealed beams are different to those on the round units. Here is the data for changing them over.
http://www.rallylights.com/hella/HeadlampWiring.aspx
Re: Round to Square, sealed beam connections.
This thread is useless without pictures......
BTW, Susquehanna MotorSports is a great retailer for all things lighting, they also frequent many of the rally events in the north east; I have met them several times...nice guys.
For the attention of 948
Had you taken the trouble to go to the link in my post you would have found a diagram of each lamp style and the designation numbers that are applicable.
Happy New Year
Happy New Year
Im pretty sure he means pictures of the TPC buckets and lights themselves....as I would like to see as well.
There you go....but we would like more close up pictures of your install.
BTW, that common phrase "this thread is useless without pictures" is truly meant in jest. I just wanted to see more of your headlight conversion....and i did go to the link; hence my mention of how good of an outfit SM is.
Today at 12:47 am by sharkey
