» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
OBDII wiring harness?
Post  joecitizennn on Mon Dec 12, 2011 1:31 pm
I have a 1997 lt1 that I need a computer and wiring harness for. Question is, can you use an earlier OBDI wiring harness and computer, or will the plugs not match the later OBDII motor?
joecitizennn
Re: OBDII wiring harness?
Post  joecitizennn on Thu Dec 15, 2011 2:47 pm
anybody?
joecitizennn
Wiring question
Post  fliermike45 on Thu Dec 15, 2011 2:50 pm
Call SSP Wiring 928-460-0764, They modified my 88 harness, very helpful guys.
Post  joecitizennn on Mon Dec 19, 2011 10:48 pm
so since this is a thread for ltx conversions, what are most of you running obd I or II?
joecitizennn
Post  msmoorenburg on Tue Dec 20, 2011 7:09 am
I'm running obd1, after some research the harness is shy 1 pin to become obd2. The ecu's are different (from what I've been told)
here is a few links where i got my info from
msmoorenburg
Post  joecitizennn on Fri Dec 23, 2011 1:11 pm
I have an oppertunity at a obd1 harness and computer, but I am scared of it because my engine is obd2. Im afraid that some of the sensors will be non compatable and I have not been having much luck with internet searches. The engine is ready to be fired and I am getting tired of looking at it every night and not being able to continue with the project.
joecitizennn
