Yesterday at 8:00 pm by Luke714
Yesterday at 12:23 pm by chrenan
» What dipstick??
Sat Jun 23, 2018 4:54 pm by chrenan
Sat Jun 23, 2018 8:28 am by rawr
Fri Jun 22, 2018 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
June 2018
Info on brakes requested
Post  Modian on Sat Dec 10, 2011 10:26 am
I'm pretty sure my electric booster has died (it just whirs continuously without building pressure) and I'm debating switching to manual brakes to simplify everything. I have several questions before doing this that I haven't really seen answered here.
  • Has anyone run manual brakes with the stock 951 calipers? If so, which MC? The Wilwood 260-7563? How is it on the street?
  • Does TPC still make the mounting plate and pushrod? I don't see it listed on their web site. (Do I even need the pushrod or will my existing one work?)
  • I'm also considering switching to hydroboost. Does anyone have a complete parts list for that, either Ford or BMW?
This is for a strictly street car at the moment.
Modian
Re: Info on brakes requested
Post  cfgioja on Sat Dec 10, 2011 2:47 pm
Im running a stock master cylinder at the moment with the stock proprtioning valve. No problems yet. I plan on upgradibg to a 928 valve for better rear braking maybe installing the hydroboost, not sure abou that yet still feeling out the manual setup
Post  marc a on Sun Dec 11, 2011 6:39 am
Not sure what modifications that you are looking to do on the braking, it is a slippery slope. I have an '86 MC that you can borrow to test whether you would like to go the unboosted route with the stock set up. The MC is probably ok, but I would go with a new one if you are happy with the results. I just need to find the pressure valve.
I also happen to have a complete BMW hydroboost set up including power steering pump, brake bomb, rebuild parts for the hydroboost MC, lines, cooler, hose, etc. You would need to make the restrictor which is pretty simple.
I also have a parts list around here somewhere, but it would be easier to do that by phone if you like. PM me
marc a
Post  Modian on Sun Dec 11, 2011 7:04 pm
Thanks, Marc, I may take you up on that. I'm waiting for a reply from ABS to see how much a new booster and accumulator will cost before I decide.
I may bite the bullet and go the larger rotor/caliper route but I wanted to see if I could get away with just a MC change right now. Maybe better to do it all now since I'm in there anyway. For your latest setup, did you have to take your car to NJ to get the caliper mount brackets fabbed? Do you know if VCI will sell another set?
Modian
