Noise.....
+2
6 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Noise.....
You ground off the 3 areas on the TOB base? If you have the D951004 casting TOB, then you are good there. It may be that your SBC/LT Flywheel is very tall and sets the clutch disc splines out to far. Just clean off about 1/8" (looks like 1/8" has been taken care of LOL)
When all bolted up and the bottom BH cover is removed, the plastic base on the TOB should be at least 1/16"-1/8" away from the base of the TOB alloy casting. If not, there is pre-load on the PP tines and can cause engagement issues.
Re: Noise.....
I really LOLed at the 1/8 inch comment Alright i will try that tomorrow and yes i ground off the 3 areas and it is the correct fitment. Ok and thanks for the info. I feel a little better now.
kelleysj- Posts : 194
Re: Noise.....
The SBC/LT1 flywheels are taller than the LS flywheels and what you just posted should be noted/wiki'ed/twittered/whatever as not to many people are doing them. I do like LT1.
What pressure plate is that and what is it's finger height from FW face. And to confirm, you are running a 153T FW?
Re: Noise.....
Which part should be ground down, the clutch plate spline or the face of the TOB shaft?
gcrind- Posts : 7
Re: Noise.....
Well both the tob before it will seat in the adapter and the clutch plate to gain clearance.
Re: Noise.....
yes it is a 153 tooth flywheel and the pressure plate is a centerforce i cant remember what model. I like the LT1 and im happy i went with it.
Re: Noise.....
Good, just don't forget to check what I posted.....
""""When all bolted up and the bottom BH cover is removed, the plastic base on the TOB should be at least 1/16"-1/8" away from the base of the TOB alloy casting. If not, there is pre-load on the PP tines and can cause engagement issues..""""
Re: Noise.....
will do i will let you know how it all comes out. Thanks again.
Re: Noise.....
kelleysj wrote:yes it is a 153 tooth flywheel and the pressure plate is a centerforce i cant remember what model. I like the LT1 and im happy i went with it.
I also have a LT1. I have no complaints... The car flys... Just watch that tach! I spun a bearing by over reving mine (100,000+km though). I just picked up a 383 beast of a motor to replace it. Should be fun if everything holds together
Re: Noise.....
Well we trimmed the shaft on the the TOB and cleaned the clutch collar up with about 1mm of space between the two that has taken care of the noise.
Page 2 of 2 • 1, 2
Page 2 of 2
