Engine location - Offset?
Well, I was measuring the area under the nose panel for a potential intake setup, and noticed my engine is not exactly centered. It is about 3/4 inch or so closer to the passenger side. What are you guys seeing with yours? The thing is, there is not a whole lt of room between the driver's side header and the frame rail. So I don't even know if I can correct this.
Re: Engine location - Offset?
You're fine. Even after moving my engine back, I left it about 3/4" to the passenger side for more steering shaft/header clearance for when the rubber engine mounts begin to sag (then I'll go poly).
If you think about it the rear CV's don't even see a degree in change....
I think every V8 out there is set to one side a little, Even our V6 conversion that we are working on is set to one side .
Tjanks for the replies, this was driving me nuts! Skywalker was kind enough to measure his last night, his is dead center. I had visions of digging out the cherry picker to shift the engine.
I was searching for something else and came across this thread. This has been driving me nuts for months as I couldn't do better than 3/4" off set and had visions of headers not fitting. Good to know.
Jim7- Posts : 51
» WTT: Early offset for late offset wheels
» Flywheel offset 85.5 944
