Ls1 Computer mounting. EmptyMon Apr 15, 2024 7:28 pm by JW1970
Ls1 Computer mounting. EmptyMon Apr 15, 2024 6:59 pm by JW1970
Ls1 Computer mounting. EmptyMon Apr 15, 2024 9:51 am by Raymond-P
Ls1 Computer mounting. EmptyFri Apr 12, 2024 3:07 pm by Rob44
Ls1 Computer mounting. EmptyWed Apr 10, 2024 10:09 pm by LS982
Ls1 Computer mounting. EmptyTue Apr 09, 2024 8:45 am by gwistrup
Ls1 Computer mounting. EmptyTue Apr 09, 2024 1:54 am by lowform
» WANTED: 948 Conversion Manual
Ls1 Computer mounting. EmptyMon Apr 08, 2024 1:52 pm by Elskeptico
» FS 1989 Transmission for 944
Ls1 Computer mounting. EmptyTue Apr 02, 2024 10:02 am by 87roadracer
Ls1 Computer mounting. EmptyTue Apr 02, 2024 6:00 am by 89EFhatch
+3
marc a
7 posters
Ls1 Computer mounting. Empty Ls1 Computer mounting.
Post  fliermike45 Fri Dec 02, 2011 10:33 pm
Would welcome any suggestions on mounting the computer. Has anybody used the glove box as a mounting option?
Ls1 Computer mounting. Empty Re: Ls1 Computer mounting.
Post  948 Fri Dec 02, 2011 11:06 pm
My computer is located where the original DME/KLR lived under the floor board.
Post  marc a Sat Dec 03, 2011 6:02 am
948 wrote:My computer is located where the original DME/KLR lived under the floor board.
X2
marc a
marc a
Post  Arthropraxis Sat Dec 03, 2011 6:57 am
That is where I put mine and the fuse box I made. I cut the flat black metal that connects the the two braces the floorboard wood bolts into. The floor insulation is still in place and the wood holds the computer still. I am going to make a strap to secure it to the wooden piece of the floorboard after I wrap the harness.
Ls1 Computer mounting. Empty Re: computer mounting
Post  l0ptbuk Tue Apr 24, 2012 12:13 pm
Am I reading this right bo understand that you guys are replacing the stock computer completely with the new computer? I plan on swaping in a Nissan RB26DEET engine, and have been trying to find anything about integrating the old and new computer together as far as controls for the entire car. Any help would be appreciated as I try to understand this portion of the swap
l0ptbuk
l0ptbuk
Ls1 Computer mounting. Empty Swap
Post  fliermike45 Tue Apr 24, 2012 12:48 pm
When you swap a LS1 computer controlled engine into a 944 the original Porsche computer is deleted along with the harness and old engine. The old Porsche computer is not used with the new engine.
You can tap into the car's wiring for fuel pump, water temp, oil pressure, rev counter and AC.
Speedometer is driven from the transaxle.
Ls1 Computer mounting. Empty RE: swap
Post  l0ptbuk Tue Apr 24, 2012 1:11 pm
Thank fliermike45! That is the info I was hoping to get before choping into the wiring! I haev traced entire wiring harnesses looking for bad links before, and I try to avoid doing that whenever possible!
l0ptbuk
l0ptbuk
Ls1 Computer mounting. Empty Remove 4 cylinder
Post  fliermike45 Tue Apr 24, 2012 4:38 pm
Look for another thread on this forum that tells you what to save from the 4 cylinder engine.
Post  Dan J Tue May 01, 2012 2:51 pm
Hi Mike,
I mounted mine under the passenger foot rest. There was plenty room and it's easy to access.
Dan J.
Dan J
Dan J
Post  Jim7 Tue Jul 23, 2013 9:42 am
I bought the car as a roller and the P'car computer was removed as was the mount.  I built a plate from Lexan and plan to attached the PCM to it by bending a piece of 1/8" x 2" aluminum into a U bracket with the PCM toward the firewall. My question is whether the thing gets hot and if I should insulate it from the Lexan.  Mind you Lexan has to be really hot before it deforms but it would suck if the floorboard deformed.
EDIT>>The PCM is designed to operate in a boiling hot environment under the hood so anywhere in the cabin will be OK. I couldn't find any info where the thing itself generates heat but to save any possible grief i'm going to isolate it.
Jim7
