» 83' Porsche 944 LM7 Build
Yesterday at 1:39 pm by Jchard944
» Throttle body question
Yesterday at 12:02 pm by Rothaus
» Oil Pan question
Yesterday at 11:58 am by Rothaus
» Posche 924 Audi 4.2 V8 ABZ
Yesterday at 11:25 am by Ralphhh
Yesterday at 10:04 am by kevin924kevin
Sun Feb 18, 2018 8:05 pm by 948
» Magnuson supercharged car?
» WTB: LS powered 968
So, after a long hiatus. I finally got to continue to where I left off.
Page 2 of 3 Previous  1, 2, 3  Next
Re: So, after a long hiatus. I finally got to continue to where I left off.
Post  aixgelo78 on Mon Dec 05, 2011 8:37 pm
Thank you for the intake idea guys. Your engine bays looks absolutely great. Puts mine to shame!!!
aixgelo78
Post  aixgelo78 on Mon Dec 05, 2011 8:46 pm
Arthropraxis wrote:[You must be registered and logged in to see this image.][You must be registered and logged in to see this image.][You must be registered and logged in to see this image.]
Anthro, were you able to bleed the brakes and the clutch easily with the location of the reservoir? The lines being a little high?
aixgelo78
Post  Arthropraxis on Mon Dec 05, 2011 9:19 pm
They bled fine. The plan was to hang the reservoir to have gravity assist if it wouldn't bleed properly.
Post  acorad on Tue Dec 06, 2011 1:50 pm
Lotsa clean as a whistle engines here, they look sweet!
Post  aixgelo78 on Tue Dec 06, 2011 2:02 pm
fliermike45 wrote:My intake installation.
Are you running without a maf? Is that a JAG's 90 elbow?
Tia
Chris
aixgelo78
MAF
Post  fliermike45 on Tue Dec 06, 2011 2:11 pm
MAF is turned down but its there to the left of the word spectre.
You can see the connector between the left two camps.
Can't remember where elbow came from, but it reduces to fit the maf.
Post  aixgelo78 on Sat Dec 10, 2011 8:34 pm
This BLOWS!!!
I have hydraulic fluid leaking from the reservoir line. Do you see how the fitting is slightly kinked? I got my braided line from Sloan.
What do I need to do to prevent this from happening again?
aixgelo78
Post  spence on Sat Dec 10, 2011 11:19 pm
The picture looks like the fitting is cross threaded which would be the reason its leaking.
Post  aixgelo78 on Sat Dec 10, 2011 11:25 pm
spence wrote:The picture looks like the fitting is cross threaded which would be the reason its leaking.
close, its the one with the roll pin holding it in. no threads there to cross. I took great care on assembling this part since it would mean major removal of either the motor or the trans. It looks like I will be pulling the trans and TT.
aixgelo78
Post  Arthropraxis on Sun Dec 11, 2011 7:45 am
That is bad news. Is it the actual line that is leaking? Someone here was able to take those lines out with the motor and bellhousing in place. I think he used a crow foot style wrench that was modified.
Post  Admin on Sun Dec 11, 2011 8:42 am
Try to move the line around a little. Looks like it may be crammed against the fire wall. See if you can get it to straighten out and that should stop the leak. It is only a roll pin as stated before, It is usually loose type fitting.
Post  xschop on Sun Dec 11, 2011 9:04 am
Spec Clutch required a TOB shim?
Post  Arthropraxis on Sun Dec 11, 2011 10:08 am
xschop wrote:Spec Clutch required a TOB shim?
There was an information sheet in the packaging that stated that if you have the F-body style slave you will need a shim using the stage 1 clutch kit. There must be a difference between the F-body and C5 slaves. I did need a shim after taking the measurements.
Post  xschop on Sun Dec 11, 2011 10:18 am
Arth, the TOB differences is a separate issue, but important and I posted every critical dimension known for AP-D951004. His pic shows the "AP" stamp on it and I cannot see the D951004 cast on it from that angle. It's perfectly fine to shim any TOB, but the input lines move in relation to the Bellhousing. Add the fact that you go from a smaller diameter factory input to the larger Russell input diameter, it looks like the fittings are hitting the BH.
Post  Arthropraxis on Sun Dec 11, 2011 11:28 am
The holes in my bell housing had to be enlarged to not pinch the lines.
Post  944-LT1 on Sun Dec 11, 2011 11:48 am
xschop wrote:His pic shows the "AP" stamp on it and I cannot see the D951004 cast on it from that angle.
Green Dot isnt replicable. Laughing
Are you sure the fluid isnt coming from the bleeder above it? Thats what it looks like to me. Make sure and see if its loose anyway before pulling the engine.
If it is tight, when installing the roll-pin fitting after removing the stock hose fitting, did you make sure that the stock o-ring from the old hose fitting was also removed from the hole after pulling the old hose out? I remember when I pulled the old hose out, to install the adapter fitting, that the old o-ring stayed in the hole and I had to fish it out with a pick. Check the old fitting and make sure the o-ring is there.
I have the another roll-pin adapter (russells) fitting here as well as an extra d951004 slave and when I insert the fitting into the hole, I cannot bend or cock or kink it like you have shown in the picture.... so maybe either the fitting is broken/bent, the roll pin isnt installed/fell out, or the slave hole is larger than what AP manufactured mine to be.
Post  aixgelo78 on Sun Dec 11, 2011 3:54 pm
Update:
The line got kinked because of the 1/8in shim. The fitting was hitting the bell housing causing the kink. As Anthro mentioned that he enlarged the hole, I did not, I did not notice it until this late in the game. I wish Spec mentioned something about this. There is no other way to take out the fitting with a wrench since a roll pin is holding it in.
I removed the roll pin, replaced the gasket of the fitting and bled the clutch again. It still leaked. I pulled on the line and it separated from the nipple. FAWK. It took me longer to take the roll pin out again since it has been slightly mushroomed since I reused it.
I have a headache now. I need to order another fitting and see if it stops the leak. I hope it does.
Thanks for everybody's input.
pics for click:
aixgelo78
Post  87-944S on Sun Dec 11, 2011 6:12 pm
Sorry to see the problems your are having, that is some gnarly rust on the TT, where do you live? Looks like what I used to deal with in Western NY.
Post  aixgelo78 on Sun Dec 11, 2011 7:06 pm
87-944S wrote:Sorry to see the problems your are having, that is some gnarly rust on the TT, where do you live? Looks like what I used to deal with in Western NY.
No worries. It sucks and it makes me loose motivation, but Im chugging along.
Yes, there is a lot of surface rust on the TT. I'm in south NJ, the car spent half it's life in Northern NJ. The body has no rust whatsoever. As soon as im done, this car will be garaged. My garage is too small to work in, so the faster I get it done, the sooner it will be inside.
aixgelo78
Post  xschop on Mon Dec 12, 2011 8:13 am
Seeing how you extracted it, you could mic the diameter of that pin and reinstall an extra long one and have it remain protruding out the TT adapter plate just like your pic. Are you able to get a dremel tool in the BH area to open the holes?
Post  aixgelo78 on Mon Dec 12, 2011 9:40 am
xschop wrote:Seeing how you extracted it, you could mic the diameter of that pin and reinstall an extra long one and have it remain protruding out the TT adapter plate just like your pic. Are you able to get a dremel tool in the BH area to open the holes?
Im sure I can fit a dremmel, but I could also fit my right angle drill if I trim the drill bit.
But yes, I ordered a roll pin kit from Amazon.com and will install a longer one for easier extraction.
aixgelo78
Post  aixgelo78 on Tue Dec 13, 2011 6:56 pm
Whats a good mic, but reasonable in price?
aixgelo78
Post  xschop on Tue Dec 13, 2011 7:08 pm
Harbor Freight has Cen-Tech brand 12" that I use for .001 The digital ones are not bad around the shop.
Post  acorad on Tue Dec 13, 2011 8:14 pm
+1 on harbor freight digital micrometer. I think they're like $10.
Post  87-944S on Tue Dec 13, 2011 8:28 pm
I own several sizes from them, always a coupon out there for them. +2!
