Brake return spring
Brake return spring
Ok, very dumb question, but I can't see where the return spring mounts on my 87 brake pedal. I can't find a good picture of one, despite a lot of searching. It looks like the early pedal has a hole for the spring. Possibly the late pedal does as well, but not on mine, unless it got wiped out when I drilled the hole for the clevis. Thanks,
Re: Brake return spring
My 87 Pedal had one and it is a bitch to get it reinstalled.
No pictures , but I have found that needle nose vise grips work wonders to get them back in place.
Where abouts is the hole? I may have to take it out and drill one, dammit! Not looking forward to this.
If anyone can measure from the top of a pedal to where the hole is, please let me know. My memory has the spring just wrapped around the brake pedal, but I can't find a picture of one anywhere, and the Porsche manual is of no help. Thanks in advance, I want to wrap this up this week, I have a few days off to work on this at the end of the week.
After a lot of cursing, and taking out the dash (got a nice leather dash to install) which gave me more head room I finally got that damn spring on. I never want to do this one again!
» Brake pedal return spring
» Can't get at the valve spring under brake master cylinder
» Difference between Wilwood Brake MC and Stock Porsche Brake MC
Today at 9:56 am by ndog52
