Exhaust Manifolds
+13
BW_Matt
stu wright
Bluemach1
Marky522
Jim7
968gene
17 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Stock Iron Manifolds for the LS3 conversion
I have a pr. of 2011 Camaro manifolds, pass. side bolted on and only minor mods to it and it looks like it will work. I wont know for sure until back from the bender on that. I cant get the car to the bender because I dont have 87 & up lower a arms to install on it yet. (This car started out as a 924S) I dont want to put them back on it just to move it to muffler shop.968gene wrote:Has anyone had any luck making a cast iron manifold work on a conversion? The 2011 Camaro manifolds look like they might work.
Anyone selling 87 up 944 A arms. If I cant make the stock manifolds work, I'd rather change the steering colum than run headers on this car.
Mike
IFC Racing- Posts : 7
Re: Exhaust Manifolds
Any updates on this? Ide like to use a set of gen 5 camaro manifolds myself, and just cut the flanges off and run some tubing to clear the steering shaft.
__Z__- Posts : 10
Has anyone tried these
or these
I don't expect to do much to my LS1 except LS3 (or similar) heads and cam so I don't think the HP gains to be made by going LTH would be worth the considerable expense.
or these
DrBoost- Posts : 32
The first set won't work because the passenger side manifold exits too far back, they are similar to early F Body pressed steel manifolds and will exit right into the firewall.DrBoost wrote:Has anyone tried these
or these
The second set may work but will require tight turns on the collector pipes, the drivers side will also have to clear the steering shaft.
For reference, 2002 Camaro Cast manifolds work but the drivers side needs to be milled at 10 degrees or so to clear steering joint.
pormgb- Posts : 186
Page 2 of 2 • 1, 2
» Looking for exhaust manifolds
» Would these manifolds work?
» Experiences with the TPC manifolds vs. headers?
Page 2 of 2
